part number?
Cloggy Saint
Post Thu Jan 01, 2015 2:19 pm
Why is there no part number for the rubber shock boot thingy, #13?
http://www.realoem.com/bmw/showparts.do ... 10&lang=en
Does anyone have it?
Post Thu Jan 01, 2015 2:33 pm
Only cars with factory fitted Bilstein dampers use that boot.
Cloggy Saint
Post Thu Jan 01, 2015 2:35 pm
And the rest, no boot :? ?
Post Thu Jan 01, 2015 2:42 pm
Cloggy Saint wrote:And the rest, no boot :? ?
Yes, just 11 and 12 which are NOT used on the Bilstein equipped car.
Cloggy Saint
Post Thu Jan 01, 2015 2:44 pm
I've just got a set of Bilstein B4 shocks, so do I need this boot and to ditch 11 & 12? And if so where can I get the part #?
Post Thu Jan 01, 2015 2:52 pm
B4s have an identical shaft / rod to the standard Boge / Sachs dampers so they utilise 11 and 12.
The only factory fitted Bilstein dampers were the B6 / B8 which have a much thicker damper rod and an internal bump stop so 11 and 12 cannot be used.
Cloggy Saint
Post Thu Jan 01, 2015 3:06 pm
Ok, thanks.
