Wheels
Sambe30
Just got some new wheels! They are genuine bbs 16" they are 5x100 so will need asdaptord or re drilling they are 8" and 7.5"
What do you recommend adaptors or redrilling?
Grrrmachine
- E30 Zone Wiki / Team Member
I recommend selling them and getting proper 4x100's.
Redrilling is not only a massive bodge, but a great way to ruin the value of some genuine BBS. Adapters aren't that strong, and will push the wheel out 20mm which may cause issues depending on the offset of the wheels. I wouldn't trust either option if you were doing any "spirited" driving.
Sambe30
ive searched for months for some in 16" and havent found any at a decent price. These ones were at a very good price and as spirited driving goes i put my foot down when i can safely haha its only a 316 so not going too quickly
Grrrmachine
So what's the ET of these wheels? That'll determine whether adapters are even an option.
ashje
What BBS do you have and what are the offsets? If they are RS's then you can swap dishes/ barrels.
Whilst not ideal adapters are a perfectly acceptable way of running wheels and 4x100 to 5x100 is easy as the holes do not overlap.
RH in germany actually design their wheels with really high offsets and then adapters/ spacers are used to get the wheel sitting perfectly. RH meet or exceed TUV standards so as long as you use a decent set of adapters and make sure they are fitted correctly you shouldn't have issues.
ashje
A redrill is also an option if they are flat backed, as for value, as long as it's done correctly 4x100 16" BBS are very desirable wheels. Again the holes will not overlap with the existing 5x100 PCD
Sambe30
They are flat backed yes, but they are 5x114 and have been redrilled to 5x100 already
Sambe30
8" and 7.5" isnt too low is it? I just don't want them to rub. Car is lowered 60mm front and 40mm rear
If they've already been drilled, it wouldn't be such a heinous crime to redrill them to 4*100, I guess...Sambe30 wrote:They are flat backed yes, but they are 5x114 and have been redrilled to 5x100 already
Sambe30
They have never been re welded, so i assume it would be ok?
Should be. Got any pics?
jmc330i
If they have already been redrilled, how much material would be left once another four holes are drilled?
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Exactly!jmc330i wrote:If they have already been redrilled, how much material would be left once another four holes are drilled?
Redrilled redrills sounds dodgy to me.
You would only use one of the five redrilled holes; the other three would be drilled in between the remaining four.
Yes but then you have less of the original material. Weakened.
Sambe30
I'm unsure as how to put pictures on here if you follow me on Instagram "sambusson" there are some pics on there
It's a lifestyle, man
ashje
Get some offsets up, they should be stamped under the centre waffles along with the original widths.
Are they split rims?
You can go quite a bit wider than what you have there on an E30, so as long as the offsets are sensible e.g et30 - 40 ish you can use adapters. If you don't mind a little poke then you could get away with et20.
To get the wheels sitting the same all round you'll need a slightly thicker adapter in the rear.
three wheels on my wagon
+ a yard full of scrap turds
Sambe30
After seeing what was said yesterday I have now got out of buying them. I have seen some bbs rm's 15 4x100 7j front 7.5j rear et33, will these fit nicely on my 316 which is lowered 40mm rear 60mm front?
Buy my nice genuine RS's that are in the for sale section.Sambe30 wrote:After seeing what was said yesterday I have now got out of buying them. I have seen some bbs rm's 15 4x100 7j front 7.5j rear et33, will these fit nicely on my 316 which is lowered 40mm rear 60mm front?
