There's a white touring 320 in my local scrap yard, is there any bits worth taking off that are hard to get hold off or worth a few quid?
shame for it to see the crusher if I can get some bits off it
touring in the scrap yard
BenHar
If the tailgate is rust free it's worth a few bob.
Ben
Ben
Motorhole
Always people looking for 51mm front struts and rear disc trailing arms!
Also the anti-roll bars (front and rear) could be considered an upgrade for most non-sport E30s.
steve_k
why not see if you can get the whole car?
then strip it & sell off the part's, makes more sense to me.
appletree
Did the 320 tourings get the bigger rear claipers too or are they on drums?
HairyScreech
Yep, All tourings have the larger rear callipers and 325 fronts.
However the fist part of any e36 calliper is the same and goes on with E30 brackets.
lhd220turbo
thanks, i'll have a closer look, someone has already had the windscreen out of it. the o/s rear wheel is not facing the right way, so its not even rolling otherwise i would have considered the whole car.
The ECU and OBC (if fitted) will be worth having.
BMW_E30vert
if it has a crack free dashboard it will be worth abit
HairyScreech
Where in the country is it? I could do with a few touring bits if you wanted to grab them.
