Fan advice
daniboi328
Post Wed Oct 22, 2014 9:36 pm
Just finishing off the s50 conversion and plan on buying a kenlowe fan as I've obviously removed the viscous fan.
My question is what's the biggest fan that will fit in the space in front off the radiator/slam panel ?
Thanks in advance
Dan
jmc330i
Post Wed Oct 22, 2014 9:44 pm
I used a 14" fan fixed to the S50 rad.
James
'91 325i Sport
'93 318i touring 16v
Post Wed Oct 22, 2014 10:01 pm
Biggest fan you can get in is whatever size the standard E34 aircon fan is. 16", I think, but I've never checked.
daniboi328
Post Wed Oct 22, 2014 10:50 pm
I only ask as I've found a new 17" kenlowe for a sensible price but don't want to buy it to then have it not fit
jimbom30cab
Tech 1 freak
Post Wed Oct 22, 2014 10:59 pm
17" will not fit. A 16" is a tight fit but will just get in.
Cypriotgeeza
Post Sun Oct 26, 2014 11:51 am
This is the set up i used on my M30B35 due to hardly any clearance..im pretty sure its a 16":
Cut down the fan and mounted it:
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
Demlotcrew
Post Mon Oct 27, 2014 9:23 am
That looks like a pull fan ^ :?
Cypriotgeeza
Post Mon Oct 27, 2014 10:02 am
Like an aircon Image
Thats an e36 one on the front aswell
Demlotcrew
Post Mon Oct 27, 2014 11:13 am
E36 fans are push not pull like the one you have fitted. Unless you can flip the blades and reverse the motor you won't have enough cooling.....
Bristol_Jer
Post Mon Oct 27, 2014 5:54 pm
I've got a 16" Kenlowe on mine, it only just fits, a 17" one wouldn't go in without a bit of bodywork chopping!
Cypriotgeeza
Post Sun Nov 09, 2014 4:09 pm
Demlotcrew wrote:E36 fans are push not pull like the one you have fitted. Unless you can flip the blades and reverse the motor you won't have enough cooling.....
Took this into consideration mate and swapped the wires around today and rechecked..fan kicks in just over the half way mark on the temp gauge and cools it down to a just over a quarter 8)
also pushes cool air into the engine bay now so i think it should be fine
:thumb:
Post Sun Nov 09, 2014 4:58 pm
Electric fan shouldn't have any effect on the engine's temp. gauge. That's not its job.
Engine temp. should be controlled solely by the coolant thermostat in the outlet elbow. Electric fan's job is to ensure that there's a supply of sufficiently cold coolant to blend into the engine for the coolant 'stat to be able to do its job.
Cypriotgeeza
Post Sun Nov 09, 2014 5:11 pm
Brianmoooore wrote:Electric fan shouldn't have any effect on the engine's temp. gauge. That's not its job.
Yep..new thermostat / fan switch / radiator in mine so all is well
:thumb:
