Your opinions if you would be so kind !
Grantley
Post Sat Jan 07, 2006 11:01 pm
I've got a standard 1990 320ise coupe and I'm thinking of getting a zone chip, my question is which one do you all think is best ? I've had all the info from Ant but still can't decide if its to be the mild or the wild one. The cars done 101,000 miles and apart from a possible air filter and exhaust change the car will remain standard, thanks in advance :cheers:
kam-325i
Post Sat Jan 07, 2006 11:03 pm
Depands, What are the differences between the Mild & Wild ?
Post Sat Jan 07, 2006 11:06 pm
personal preferene I think mate. From what i have seen posted, wild is the one to go for if you plan on furher mods like exhaust, maybe cam and other stuff.
Mild will still provide you with an improved driving experience
Grantley
Post Sat Jan 07, 2006 11:08 pm
The mild keeps the same idle and smoothness of the engine but gives increased drivability and a slight increase in power through the rev range. The wild makes it idle higher (900 rpm), changes the rev limiter to 7000 rpm and gives a larger increase in bhp pulling harder at the top end.
dazleeds
old skool raver
old skool raver
Post Sat Jan 07, 2006 11:11 pm
wild and a 325 throtle body :cool:
www.oldskoolfantasy.co.uk
demonbiker
Post Sat Jan 07, 2006 11:19 pm
Ive got a zone 1 chip big bore throttle body full stainless and a k&n filter--
YEAH BABY!! goes well !!
:mad: :mad: :twisted: :cool: :cool:
'90 M5 3.6 "Driven Hard......Put Away Wet!! "
herman
Post Sat Jan 07, 2006 11:20 pm
Stress it, could go bang with those miles. 7k in a 6 pot, It's not a revy engine without the balancing. You know what it's like when you start in 1st, some times it does not want to go. Be carefull.
When they wanted to beef up an engine, they went for a 4 pot.
