It's ok, you can laugh at me, but I really dont want to ruin my new E30, and I have never jacked up an E30 myself.
Nothing to be worried about asking, everyone has to start somewhere, I had the same worries when I first started tinkering with cars... I used to jack my car up through gritted teeth...Wega wrote:
That's what I have, and do, to raise the car with a jack, but you can't put stands in the same place as the jack!daimlerman wrote:Another option is to make up a few packing pieces from plywood and use the rear cill jacking point for your stands.
I raise the car using either 'drive on' ramps or jack under the diff or the beam bush mounts to get the thing high enough to support by the cills.Brianmoooore wrote:That's what I have, and do, to raise the car with a jack, but you can't put stands in the same place as the jack!daimlerman wrote:Another option is to make up a few packing pieces from plywood and use the rear cill jacking point for your stands.
