Lsd clutch and friction plates
jasso
Post Mon Jul 28, 2014 12:27 pm
Hi can anyone recomend were to get Lsd clutch and friction plates from??
Post Mon Jul 28, 2014 1:02 pm
Try PMing gareth on here - he rebuilds diffs.
http://www.e30zone.net/modules.php?name ... file&u=457
jasso
Post Tue Jul 29, 2014 8:40 am
Has anyone got a contact number for him?
DHFiS
Post Tue Jul 29, 2014 6:10 pm
I used this site
http://www.driveandtraction.blogspot.co.uk/
No phone number, only contact by email.
jasso
Post Wed Jul 30, 2014 8:14 am
Will give them a try, the problem with my unit is that at times it locks up and at times it doesn’t, you can hold the input flange and freely turn the output flanges would this normally indicate that the clutch is knackered? Pinion and crown wheel are fully in tact
jasso
Post Tue Aug 05, 2014 8:24 am
How much percentage does the lock up increase by when adding a extra 2 clutches and 2 dog ears??
gareth
Post Mon Aug 11, 2014 6:21 pm
As above, I use driveandtraction plates and have never had a problem with them.
If you're going from 2 plates and 2 dog ears to 4 plates and 4 dog ears, then the lock doubles (from 25% to 50%)
Beware machining the 168mm spool end cap though, they're weak enough as standard and are all to fond of shattering even before metal is removed! Steel replacements are available though
BONNARSKI
Post Fri Aug 15, 2014 11:01 pm
I'm planning to rebuild my LSD soon but it was along time ago that i read up on rebuilding an LSD.
Is there a write up about adding more plates into the standard LSD as from what i can remember it was just a case of removing a shim and replacing it with a clutch and a dog ear but seen that a spool cap needs machined.
Anybody help here?
gareth
Post Sat Aug 16, 2014 8:49 am
That's right, once it's in bits you'll see the shim (4mm) that needs removing. The same needs to come off the other end of the cap
I can do diff machining and rebuilds etc but not for the next month or two as i've got a new baby and a stressed new mum to look after. :)
BenHar
Post Sun Aug 17, 2014 12:00 pm
gareth wrote: i've got a new baby and a stressed new mum to look after. :)
Congratulations, Gareth.
Ben
gareth
Post Sun Aug 17, 2014 8:30 pm
Cheers :D
