BMW E30 Foglight's Not Working!
MPOWERCRAZY
Post Thu Jul 24, 2014 2:48 am
Hi All,
When I Turn The Front & Rear Foglight's On Nothing Shows On The Dashboard, What Could This Be?
mark_i
Post Thu Jul 24, 2014 6:46 am
bulbs in cluster, relay or fuses...
Post Thu Jul 24, 2014 9:46 am
Depends rather a lot on whether the lights themselves work, which you don't say.
povertyspec
Post Thu Jul 24, 2014 9:55 am
same thing happened to me when i got a new 325. the culprit turned out to be a dried out switch, because the dash cluster hasnt illuminated no power has got to the cluster from the switch. it could be a jammed relay or the fuses (fuses supposed to save the bulbs from damage anyway)could have blown but i would go for replacing the switch.
povertyspec
Post Thu Jul 24, 2014 9:57 am
just thinking but if you dont have a multimeter any on off switch that connects the terminals behind the switch once youve removed it will tell you if the fog lights work. you could try soaking the switch in WD40 overnight.
MPOWERCRAZY
Post Thu Jul 24, 2014 10:54 am
Thanks for all the comments, will check today for fuses & swop of relay.
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
Post Thu Jul 24, 2014 2:21 pm
Brianmoooore wrote:Depends rather a lot on whether the lights themselves work, which you don't say.
