new e30 owner need a little help
joeadams1979
Post Sat May 24, 2014 3:15 pm
Well i sold my 200sx due to blowing the engine and took in a nice clean 325se 2 door in part exchange.It drives really good bodyworks nice and straight ive ended up removing the complete carpets seats door cards. to replace them with a nice leather set and new carpet since the old one was ripped and not in good condition.Yesterday i went to take it for a quick drive with just the drivers seat bolted in as i got in ive noticed a puddle of water behind the driver seat rear passenger foot well i looked for any leaks etc couldnt see any rips in the seals on the door or sunroof letting water in and today its full of water behind the seat agein ive attached some photo if anyone could suggest what to check or see where abouts it coming from.
Ive attached the photobucket link below kind regards Joe
http://s30.photobucket.com/user/mrjoead ... t=3&page=1
Post Sat May 24, 2014 3:20 pm
Try using a curtain wire or bicycle brake cable to shove down the sunroof drain channels to clean them out.
gooner1
Out humping Reindeer
Post Sat May 24, 2014 3:21 pm
Do a search for cleaning sunroof drains Joe.
joeadams1979
Post Sat May 24, 2014 3:23 pm
Does it look like its the sunroof leaking ?
gooner1
Post Sat May 24, 2014 3:26 pm
Not talking sunroof leak, Joe, I mean the drains that lead from the sunroof.
Very hard to tell from your pics mate, but looks like corrosion has been going on for a while.
That brown splodge is rust, isn't it?
joeadams1979
Post Sat May 24, 2014 3:42 pm
been looking online con't seem to find a step by step on it ive got a curtain wire ready so ive got to open the sunroof push it up and down a couple of times at the drain plugs with the wire and hopefully clean it out
Post Sat May 24, 2014 3:50 pm
Yes. You could also run a hose down the channels to help flush out any crud.
http://www.e30zone.net/e30zonewiki/inde ... of#Sunroof
gooner1
Post Sat May 24, 2014 3:52 pm
diable wrote:
joeadams1979 wrote:Does it look like its the sunroof leaking ?
The drain holes may be blocked so the water is not dispersing as it should do.
My roof leaks but I have a cabriolet :( :D
Maybe, but you still have drain holes.
joeadams1979
Post Sat May 24, 2014 5:47 pm
thanks guys just been outside used curtain wire the plugs on the sunroof am guessing were the two holes on eachside of the body. Under the sunroof gave them a good once over and cleaned out all the water hopeful no more water. il have to see torrow p.s that was a sponge not rust :-) thanks everyone il keep you posted
Post Sat May 24, 2014 6:01 pm
did you notice any crud on the curtain wire or did any come out of the flap by the bumper ?
joeadams1979
Post Sat May 24, 2014 6:25 pm
nope ;-(
Post Sun May 25, 2014 8:30 pm
how you getting on with this ?
dry the insides out then sit inside the car and get someone to run a hose over the roof .
joeadams1979
Post Mon May 26, 2014 11:15 am
Gave it a try didnt have any water to report back but this morning checked and ive got a puddle yet again. if i block the sunroof drains with a grommet will it still lead to water in the floor?
Post Mon May 26, 2014 12:32 pm
i wouldn't do that lol ,
Post Mon May 26, 2014 12:39 pm
I would sit in the car in the next heavy downpour (or get someone to run a hose over it) and observe to see where the water is coming from.
gooner1
Post Mon May 26, 2014 12:42 pm
After you cleaned out the drains, did you run any water through them, if so did the "fresh"
water emerge from the sill holes?
joeadams1979
Post Mon May 26, 2014 2:55 pm
didnt run the water after i cleaned them not sure i did a good job at it cont seem to find a step by step for dunbiees on the internet :D is their a guide to referee to on here
gooner1
Post Mon May 26, 2014 3:11 pm
Try the curtain wire again until you see the water emerging from the cills.
You need to make sure the wire is going into the drains as far as possible,
not getting stuck and doubling up on itself.
As others have said though, run a hose over the roof/car as well, whilst you are sat
in it.
joeadams1979
Post Mon May 26, 2014 5:48 pm
will do il have to pick up some metal wire up at bnq and give it a shot may i take this time and thank everyone for so much help realy appreciated will keep you all posted on the results :D
DHFiS
Post Mon May 26, 2014 6:16 pm
Is the plastic sheet behind the door card still attached to the door and is it still sealed along the bottom edge?
The rear sunroof drains empty out of the car through a flap in the boot behind the wheel arch. If you pull the trim out of the boot you will see them.
Post Mon May 26, 2014 6:52 pm
Just realised that this is a parallel thread to one in the tech. help forum, where this thread should be anyway. Any further replies in that thread please!
