Drifting
pony
Post Thu May 08, 2014 6:53 pm
I always thought to drift you needed a LSD or welded diff
Just saw this post where 120d is drifting with open diff
How is that possible with open diff ?
http://www.e90post.com/forums/showthread.php?t=522718
What are the major differences in drifting with LSD v drifting with open diff ?
Thanks very much
Post Thu May 08, 2014 7:03 pm
Any RWD car can be made to drift quite easily, given a slippery enough surface and a reasonable amount of power, even a Morris Minor!
pony
Post Thu May 08, 2014 7:08 pm
I think with LSD feels a bit more controllable and progressive when is drifting (than open diff)
Get more traction too from tight corners
pony
Post Thu May 08, 2014 7:09 pm
Speedtouch wrote:Any RWD car can be made to drift quite easily, given a slippery enough surface and a reasonable amount of power, even a Morris Minor!
The Morris Minor isn't lairy thoygh
Post Thu May 08, 2014 7:10 pm
The only RWD car I've ever had difficulty drifting was a 594cc Fiat 126 - it was so gutless, it would struggle to pull a wheelspin on loose gravel!
GB69
Post Thu May 08, 2014 7:29 pm
I've drifted with all 3. Open diff is ok when drifting in 1 direction, try transitioning and its much harder to link a course. LSD is ok if its in good order, most are crap and wont lock as much as they should, a welder is much better as you know its locked and will be very easy to skid. Drifters either use welders or 1.5/2 way LSD.
Andyboy
Alpina Colada
Post Thu May 08, 2014 7:38 pm
diable wrote:Real drifters don't need LSD's
Exactly. The bloke who owns Longstone tyres can drift a 2.0 Mark 5 Ford Cortina like a pro.
Bristol_Jer
Post Thu May 08, 2014 7:46 pm
Ideal job to be in for a drifter winkeye
pony
Post Thu May 08, 2014 9:02 pm
GB69 wrote:I've drifted with all 3. Open diff is ok when drifting in 1 direction, try transitioning and its much harder to link a course. LSD is ok if its in good order, most are crap and wont lock as much as they should, a welder is much better as you know its locked and will be very easy to skid. Drifters either use welders or 1.5/2 way LSD.
Aren't standard BMW LSDs for E30s 2 way ?
GB69
Post Thu May 08, 2014 9:05 pm
Nah doubt it, 2 way LSD like KAAZ are £1,000 plus.
pony
Post Thu May 08, 2014 9:09 pm
With an open diff you can get in a slide but holding the drift and/or transitioning the drift eg figures of 8 isn't that difficult with open diff ?
Every drifting guide I have seen on the Internet says you need RWD and LSD (or if you are tight welded diff). I would just be concerned about the safety aspects and legality of welded diff.
Presumably the same skills are required whether you have LSD, open diff, welded diff.
I have had some sideways moments with E30 and open diff using power oversteer (ie too much throttle on exit), lift off oversteer (ie lifting off in the middle of the corner) or braking in the corner (I don't know what the technical drifting technique for this one is called)
I haven't tried clutch kick, dirt drop techniques
Never done any donuts in my own car or proper burnouts
And I am ashamed to admit I don't know how to do a handbrake turn
Maybe some one can teach me on here :-) ????
Just learning how the E30 is with LSD and getting used to it.
DANNYM
Post Thu May 08, 2014 9:25 pm
best thing to do is take it to a dead road and abuse it that's the only way your gona learn :D
rh306
Post Thu May 08, 2014 9:35 pm
I thought the OP was an OEM Homo type, bit surprised to hear about the new drifting career. Wouldn't a more executive form of motorsport be more suitable? :?
Motorhole
Post Thu May 08, 2014 9:48 pm
You definitely know about clutch kick when you do it accidentally 8O
Post Thu May 08, 2014 9:49 pm
rh306 wrote:I thought the OP was an OEM Homo type, bit surprised to hear about the new drifting career. Wouldn't a more executive form of motorsport be more suitable? :?
He's an Ilford boy, the streak is a mile wide ! :)
pony
Post Thu May 08, 2014 9:50 pm
Lol what made you think I was OEM homo type rh306 ?
pony
Post Thu May 08, 2014 9:51 pm
LOL
Essex boy Peter!!!!
Gert_8
You got the homo bit right! :D
Pony just realised he's wasted a lot of money on his recent purchase.
pony
Post Thu May 08, 2014 9:53 pm
Gert_8 wrote:You got the homo bit right! :D
I haven't wasted any money u cunt
gareth
Post Thu May 08, 2014 10:10 pm
pony wrote:Aren't standard BMW LSDs for E30s 2 way ?
Yes they are. Yours is :)
They can be altered for different lock percentages for drive and coast too, making them 1.5 way.
Get yourself to a drift day and find someone who knows their shizzle and get them to take you out and show you the ropes. Plenty of people there to lend a hand and advise. Despite their tatoo'd faces, most drifters are pretty friendly :)
I learned to drift the old skool way, in a mk2 escort (when they were £500 for a minter... mine cost £70!) in a gravel car park. Less grip and less speed is handy when you're learning.
If you can find a skid pan day you can learn loads at lower speeds and with less stress on the car (even someone else's car!) to save the embarrassment and hassle/cost of binning your car with an audience! :D
rh306
Post Thu May 08, 2014 10:11 pm
..not sure, I remember some heavy love for that Park Lane E21 a while back. Good to see you posting again though, zone legend IMO :thumb:
rh306
Post Thu May 08, 2014 10:19 pm
diable wrote:
rh306 wrote:
pony wrote: Lol what made you think I was OEM homo type rh306 ?
Are you in love?
..sounds like I might have missed that particular boat 8O
pony
Post Thu May 08, 2014 10:22 pm
Yes I am half OEM homo half wide boy
Gert_8
Post Thu May 08, 2014 10:23 pm
I haven't wasted any money u ****
Hahahaha. You charming mongtard. :D
pony
Post Thu May 08, 2014 10:25 pm
Cheers Gareth :-)
I am thinking of getting some cones from eBay and finding an empty car park or doing a DWYB day.
Had a little sideways moment when there was a kink on wet road today and weren't even giving it the full beans. Taking it easy ATM
ross_jsy
Post Thu May 08, 2014 11:25 pm
I see this ending in tears.
Get plenty of pics when you bin it :D
Gert_8
Post Fri May 09, 2014 8:07 am
Remember that video of the kid that borrowed his mum's car and ended up hitting a lamp post head on?...... Pone's future. :)
pony
Post Fri May 09, 2014 8:53 am
This is what I love about the Zone so much positivity ! A true credit to the Zone ethos !
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri May 09, 2014 9:47 am
A bit of ribbing is in the Zone spirit. Outright insults are not.
Play nice, gentlemen.
