Newly fitted Limited Slip Differential
pony
- I have been misbehaving and am sorry !
Hi I have just had new LSD fitted (fully rebuilt by Gareth, 40% lock up, 3.91) to my E30 325i Sport (1987).
I previously had an open diff and have had some sideways moments in that.
I haven't driven this E30 for about 2 years.
Are there any special running in procedures ?
What can I expect in terms of handling differences ?
Will it drift and go sideways much more easily now ?
Will it be easier or harder or the same to control when going sideways ?
ross_jsy
It will understeer more however oversteer is easier to provoke and control.
To be honest there are far better upgrades you could have made for the cost of a modded diff, unless it's being used on track I can't see the point
pony
I am using it as a daily and hopefully touch wood DWYB days once per month.
Looking back I was thinking maybe a Kaaz 2-way LSD or Quaife LSD as other alternatives but in the end chose this option as was certainly a lot cheaper than a New Quaife LSD and was closer to retaining a philosophy of using Genuine BMW parts as much as possible.
pony
Dont I have to break it in with figures of 8s at very slow speeds ???
maxfield
I nice tight rear end is a good upgrade if you ask me Ross
ask pacer.
You don't need to run it in.
Will definitely improve handling/grip and be more controllable sideways.
ross_jsy
Ask Gareth, he is the diff expert.
pony
I have brand new Powerflex bushes
Rear beam
Rear trailing arms
Rear anti roll bar bush
Rear diff bush
These are all Powerflex
The front bushes are all BMW and I think eccentric E30 M3 bushes
Rear beam
Rear trailing arms
Rear diff bush
ross_jsy
I've heard that's why you aren't his favourite any moremaxfield wrote:I nice tight rear end is a good upgrade if you ask me Rossask pacer.
you can steer from the rear with an lsd
open diffs are for real men !
+ a yard full of scrap turds
craigieeb
Yes, yes you do and we need to see the evidence !pony wrote:Dont I have to break it in with figures of 8s at very slow speeds ???
M50 Turbo!!!
I shall say no more
pony
So is anyone here going to give specific advice on breaking in LSDs or what ????
I saw a site which says do figures of 8s for 30 minutes and accelerate at 20km/h in the straight in each gear
How the hell am I supposed to do that ????
pony
Instructions here what do u guys think ?
http://www.driftworks.com/forum/technic ... w-lsd.html
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
That's bollocks. Did the manual say to do this on a new car with an LSD factory fitted?....use your sense.pony wrote:So is anyone here going to give specific advice on breaking in LSDs or what ????
pony
What I mean is I am using this for daily and drifting and the LSD is updated from the standard BMW 25% lock. So don't I have to run in ?
SDM
- Formerly WhiteM3
you have to do donuts in mcdonalds car park for 10 minutes (5 minutes each way) whilst holding 5k revs in 2nd to break it in.
Gert_8
Sorry. Let me rephrase that last statement.
I do not believe the user manual supplied with an original sport fitted with an LSD, from the factory, advised you should do figures of 8 for 30 minutes and then accelerate at 20km/h in the strainght in each gear..... that's just stupid.
pony
Have a look at the other running in advice in the link I posted above and tell me whether u agree/disagree with that as well ?
capnmchl
More chance of spinning in the wet, or in any slippery conditions...
Gert_8
Yep, I still think it's pointless.
pony
All I want to do is make it last as long as possible so if I have to follow a running in procedure I will do and vice versa
Cost a small fortune and for me is the best part of it
Gert_8
If you want to make it last as long as possible, may I suggest you don't go drifting then?
pony
I mean I want to make it last as long as possible for the application of drifting (if that makes any sense)
Of course drifting will increase the wear
gooner1
- Out humping Reindeer
Ross has already given you the best advice, probably.
" Ask Gareth, he is the diff expert. "
harry_p
No, it's not extreme enough to need a specific running in procedure.pony wrote:All I want to do is make it last as long as possible so if I have to follow a running in procedure I will do and vice versa
You don't need to do anything special, but like any recently changed mechanical component it's a good idea to do a few 'normal' miles and gradually build up loads / temperatures rather than bolting it on and going straight out for a half hour drift session.
But I think that's just my preference for a bit of mechanical sympathy, and probably isn't necessary.
Changing the oil after the first 1000 miles or so after a rebuild isn't a bad idea either, although again, with modern materials and oils probably isn't really necessary.
cheers,
harry
harry
i'd be looking at the rear beam bushes before you start diffin .
magpie wrote:i'd be looking at the rear beam bushes before you start diffin .
It's all new, she's fully motorsported up with lots of new poly bitz. He's off to Wales on the weekend for a BMWCC sausage fest so the sheep better be on their guard, an out of control Tech 1 has got to hurt more than a boyos knob
fookin creased up herepacerpete wrote: an "OUT OF CONTROL "Tech 1 has got to hurt more than a boyos knob
ross_jsy
Let's just read Gerts sig to remind ourselves of Pony's drifting skillz
Gert_8
Here it is to save you searchingross_jsy wrote:Let's just read Gerts sig to remind ourselves of Pony's drifting skillz
jmc330i
I'm sure the working life of an LSD clutch pack (where the clutch is actually 'locking' up) is measured in hours....
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
maxfield
About 8 hours I believe from factory.
ross_jsy
Sounds about right. Also iirc higher % diffs wear quicker, but may have that wrong
I've done about 10-15 sedate miles in it since fitted, its ready to go side ways now!
gareth
Just get in and put a few miles on it before going silly. drop the oil after a few K and throw new stuff in and it'll be fine.
The last diff I shipped out got bolted up the arse on a full race E36 M3 Evo, driven across a car park, onto a trailer, towed to the 'ring, straight out on track and started qualifying! The following day it came second in class at a 4 hr VLN endurance race! No bed in whatsoever
Oil came oit clean as a whistle post race
At the end of the day, it's a bunch of metal bits sliding around other metal bits. Use some mechanical sympathy for a while as parts bed in together, followed by an oil change to clean out the deposits from this bedding in period.
pony
Thanks Gareth having been taking it easy
