Hi, I have posted a WTD in the parts section but I was wondering where to procure a drivers side front wing for my 1990 face lift cab?
Flute.
Wtd- where to purchase a drivers side front wing for my cab?
- **BANNED**
Brand new will only be available from the dealer,be seated when asking;
'HOW much?'
Why do you need a wing?
If it's just the area below the cill trim strip that is tatty,a decent body man will be able to make a repair section up for you.
'HOW much?'
Youth is wasted on the young.
pac1982
Surely you can buy pattern parts somewhere? I'm currently looking for rear arch repair panels for a convertibledaimlerman wrote:Brand new will only be available from the dealer,be seated when asking;
'HOW much?'
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
- **BANNED**
Cabbie's have deeper cills than the rest of the range,so pattern wings are not a direct fit.
If you examine your cabbie's lower rear front wing's corner(the bit next to the cill)you will note that the lower bit is spot-welded to the main part of the wing,it is this area that is unique to the cabbie.This part can be re-made as I mentioned above.
Rear arches.
A pattern arch section is available for saloons,but once again,it is not a direct fit to a cabbie for the same reason that front wings for saloons do not fit.
However,it is possible to adapt these sections to fit,if you are a decent metal worker.
Remember,far more saloons/tourings were built compared to cabbies,so pattern parts have just not been made due to the relatively small numbers of cars built.
Rear arches.
pac1982
I did realise the sills were deeper, I first found this out the day I picked it up, I stopped at the petrol station and fell face first out the car tripping myself on the inner sill as I was so used to the depth of normal E30 sills loldaimlerman wrote:Cabbie's have deeper cills than the rest of the range,so pattern wings are not a direct fit.
Rear arches.
The guy whos doing work did say he could make non cabby arches fit but i wanted to buy the right part in the first place if possible, if your saying they just cant be found then i may as well revert to plan B and let the guy work his magic with a normal arch repair panel. He sounds quite legit and even said he would be using the nice old skool method of leading which was nice to hear
- **BANNED**
DaveyB
i have a pair of wings in telford shropshire
Wanted Nothing atm
Mitchen
- **BANNED**
That's a saloon wing!Mitchen wrote:http://www.eurocarparts.com/ecp/c/BMW_3 ... ba8&000375
Will need the cill part adapting to fit a cabbie.
alpina123
There not that dear from bmw
Flute
Been quoted around £190 from bmw. I think this is a bit dearalpina123 wrote:There not that dear from bmw
Flute.
cossy14
i just purchased front drivers wing off a tc baur thinking they wer same so i got to fabricate mine but even worse i bought car with no wing so i got no bottom section to use
darkchild
They're not cheap but remember it's for a car that's been out of production for 20 years. Most other car manufacturers would be nla for similar aged vehicles.Flute wrote:Been quoted around £190 from bmw. I think this is a bit dearalpina123 wrote:There not that dear from bmw
Flute.
