cleaned my air box etc....
hammersfan12
i cleaned out my air box because i found oil in it, and the the boot. i put it all back together took it for a drive and it ran fine. then after about 5 minutes bogged down. i did leave the top part of the box in hot water for a bit. could of i damaged the electrics. thanks
ross_jsy
Wait, did you soak the AFM?
hammersfan12
....yeah, i thought where it was sealed it would be ok. will it just need to dry out.
Rich320I
it may just need to dry out (airing cupboard) but it may be fubared fella, the wiki does show how to test
hammersfan12
shit, knew it was a bad idea to not take it out why i cleaned the rest. and hopefully will dry out. how much are they to buy second hand/ new usually.
Rich320I
roughly:
http://www.ebay.co.uk/itm/Bmw-E28-E30-3 ... 566219f3a2
but they vary in price, it may well dry out tough and its always worth testing before buying anew one.
hammersfan12
not too bad, i had a look on the wiki bit but i couldn't see how to test it.
ross_jsy
Some people really should just pay people to work on their cars!
How much oil was there? Surely a wipe with a rag with brake cleaner on would have been a better option
hammersfan12
not much, i admit it was a stupid decision. as i said i should of taken it apart at least. see how it goes tomorrow if not have to get a new one.
Bit of water in it for a short while won't cause any serious permanent damage, but you'll have to prise the cover off to dry it out, and reseal afterwards.
Sure it's not a split in the convoluted rubber air pipe?
hammersfan12
ah k, and the boot has just been replaced not with new. but had no splits in it. and checked when i put it back on
hammersfan12
just started it, struggled so i kept dipping the throttle it then idled. drove it it was bogging then picking up so think it just needs to dry a bit more.
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
If it needs drying out, can I suggest you put it into the airing cupboard, or better still put it into a bag of rice.
hammersfan12
ok, ill take it off and try it.
gooner1
- Out humping Reindeer
ross_jsy wrote:Some people really should just pay people to work on their cars!
Wouldn't be much use for the Technical section if that
was the case.
Geezer fucked up, who here hasn't at some point.
Gert_8
Quite right. All part of the learning possessgooner1 wrote:ross_jsy wrote:Some people really should just pay people to work on their cars!
was the case.
Geezer ****** up, who here hasn't at some point.
