Gearbox
Fastroad
Post Thu Feb 20, 2014 9:55 pm
Thinking of purchasing a dogleg gearbox for 325i sport M20.
Does anyone know if there were different versions of dogleg gearbox for the M20 or only one type?
Part numbers would be handy and any idea of what they cost nowadays.
Also what do members think of having a dogleg gearbox in a sport ??
Thanks in advance to any helpers
Post Thu Feb 20, 2014 10:14 pm
Why bother ? :? You will need a box, the prop and a different diff. £1000 + for no gain .
ross_jsy
Post Thu Feb 20, 2014 10:56 pm
Pretty pointless unless you are racing, and even then there are better things to spend a grand on.
Post Thu Feb 20, 2014 11:12 pm
I looked into doing this then though better of it.
The dog leg box that fits direct onto an M20 and was available as an option on the 323i was based on the weaker 240 gearbox.
You can use a E28/E24/E30 M3 265 dog leg box which is stronger but you need the bell housing from a US spec 528e to bolt it up to an M20.
As said, you will need to change the ratio of the diff and also the prop and gear linkage.
Fastroad
Post Sat Feb 22, 2014 5:49 am
pacerpete wrote:Why bother ? :? You will need a box, the prop and a different diff. £1000 + for no gain .
Wow the price it's self is a deterrent.
Fastroad
Post Sat Feb 22, 2014 5:52 am
bss325i wrote: As said, you will need to change the ratio of the diff and also the prop and gear linkage.
What ratio diff would you say matches the dogleg box and I am guess it must be different in length hence the changing of prop? And would that mean custom prop or a different model?
ross_jsy
Post Sat Feb 22, 2014 12:46 pm
You need an m3 prop and linkage and a 3.15 diff iirc
Fastroad
Post Sat Feb 22, 2014 11:10 pm
Thanks for all the replies.
Fastroad
Post Wed Feb 26, 2014 6:33 pm
Anyone recognise these numbers
Which version of Getrag M60 box this is?
Fastroad
Post Wed Feb 26, 2014 9:56 pm
Anyone?
