buying a used lightened flywheel
NoTurbo
Would any of you buy a ragged lightened flywheel?
What are the risks of it cracking?
ross_jsy
Voted yes, depending on how much it has been lightened. There is a safe minimum you can take them down to
Automaton
Wouldn't take a chance, might save me money now, but may have to pay a lot more if things go awry.
PWPF
PWPF
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
A "ragged lightened flywheel"?
Whats that?
Whats that?
gooner1
- Out humping Reindeer
Seeing as most, if not all, are secondhand I vote yes.
Pretty sure you would be able to get it checked, if you were dubious about it.
Meatballs82
Voted yes, I had one fitted to mine this year - no problems so far!
NoTurbo
haha, sorry for the slang.DanThe wrote:A "ragged lightened flywheel"?
Whats that?
Ragged means it has come off a car that was raced regularly and driven hard for most of its life
Split_S
- POR 15 junkie
Some stuff I just won't buy used.... If you're gonna go thru the hassle of changing a flywheel, do it right man! For the little $ you'll save is the risk worth it?
Me thinks not...
I'll be changing mine and Im going with an aluminum machined flywheel made specifically for the job. Not cheap, but I wont be changing it out a month later Im pretty sure...
Me thinks not...
ross_jsy
Thing is it's a big chunk of steel. Not much that can go wrong with it bar maybe excessive wear/heat distortion but that will be evident just by looking at it.
Split_S
- POR 15 junkie
Still, I always wonder why the guy would be selling it in the first place... If youre gonna do the install yourself then go for it if its cheap but then again - I wouldn't.
Its not something that goes wrong often unlike dual mass.
some rubbish being said here! holy moly
maggspower
- Turbo Farmer Tractor Driver
There is very little to go wrong on a fly wheel, the ring gear, and the clutch friction surface. Never seen a worn out ring gear on an e30, and the clutch surface can be reground.
Hairyscreech ran a computer simulation on a lightened flywheel, it had less stress on it than a standard one. The stress is centered around the mounting holes, so any material removed from the outer edge lessens the centrifugal force placed on it.
I have never heared of anyone losing their feet in an exploding flywheel incident, there is allways a first though
I can lighten and balance, flywheels here, if anyone needs one doing. Group buy?
Contact: theengineshedonline@gmail.com
ross_jsy
Always is now Simon.
Maggs, I have seen some grim pictures of flywheel failures...on sub 9 second drag racers not sub 200hp road cars
maggspower
Yes my mistake, it should have read "in an e30", I have heard some nasty story's too.ross_jsy wrote:Always is now Simon.
As for spurious information, well.......
Some alloy flywheels are known to fall apart, ive never heard of a BMW flywheel breaking up, road or racing use, ive seen one thats come off the back of the crank on a race car but it didnt rip through the floor or anybodies limbs, just took a lump out of the gearbox.
