Glovebox torch avalibility
sweep
As above.
Jesus325iTouring
- Frog freak !
Many are hiding down the inside of the centre consol, does that help?
Cloggy Saint
Andyboy
- Alpina Colada
I found a working one in a scrapper last week! Was getting dim, but half an hour plugged into the car and it was glowing nicely.
sweep
adit
i have loads of these Pete.
i did have a few which actually worked
, but that was a year or two ago.
there may be a cheap "refurber" around somewhere
[quote="bss325i"]
They can be carefully opened up and new batteries fitted (CPC-Farnel) as long as the brass bits aren't too corroded.
Would be nice to covert to a white LED while it's apart, but a higher voltage battery pack would be required.
adit
ok, thaqnks for that Brian. i'm not sure that the OEM homos would be too pleased though
[quote="bss325i"]
sweep
oem is where its at.
jamlid
I've heard you can transplant the insides of a modern glovebox torch into an older torch.. Sure there's a guide on the internet somewhere.
appletree
This might be some good, looks like a e36 install but I'm sure some early e36s used the white torch untill they changed to the black ones.
http://forums.bimmerforums.com/forum/sh ... alling-LED
pukar
I have a spare one for refurbing, if anyone's interested...
polsta
brian you should offer up a postal service to do this for people and earna few quid !!!Brianmoooore wrote:They can be carefully opened up and new batteries fitted (CPC-Farnel) as long as the brass bits aren't too corroded.
polsta
when i stripped my dash out, i found my it tucked right away, probably the cars original, pleasing to findJesus325iTouring wrote:Many are hiding down the inside of the centre consol, does that help?
Cloggy Saint
sweep
where can i buy the batteries?
CPC/Farnell.
They seem to have permanently dropped their prohibitive postage and packing charges on orders under £40.Speedtouch wrote:CPC/Farnell.
adit
rather like the interior lights thenCloggy Saint wrote:
Maybe with a LED they'd become a bit more useable, as let's face it, the standard item is utterly useless!
[quote="bss325i"]
Never seen a 36 with a black torch. They all had white ones.appletree wrote:This might be some good, looks like a e36 install but I'm sure some early e36s used the white torch untill they changed to the black ones.
My 99 V plate convertible had a white one.
sweep
right thats it...the car is a 1990 and the torch battery's have gone after twenty three blooming years its a disgrace im going to ring sytner in the morning and make a complaint.
That was the change over. As far as I know, ALL e36's had whitediable wrote:The E46 had the black ones.B7 wrote:Never seen a 36 with a black torch. They all had white ones.appletree wrote:This might be some good, looks like a e36 install but I'm sure some early e36s used the white torch untill they changed to the black ones.
pukar
OR YOU COULD JUST BUY A NEW ONE!
i bought one about 1 year a go, brand new in a box, and as B7 was saying for an E36 and it is perfect.
http://www.realoem.com/bmw/showparts.do ... =30&hl=237
Chargeable hand lamp 82119413147 $27.25 +core
Fooooking paedos !
maggspower
- Turbo Farmer Tractor Driver
Barry, it seems that I can put any part number into that link, and it gives me an accurate price.
Why have I not been told of this before?
Contact: theengineshedonline@gmail.com
Cloggy Saint
Sometimes things go either NLA or worldwide major back order and then get reproduced again when demand increases and BMW order another batch of a part, usually at an increased cost.diable wrote:http://www.e30zone.net/modules.php?name ... highlight=
Must have lied to me........
Can you get some Barry?
I'm not back at work till wed so cant confirm either way till then.
Good WORKING used ones here !
