I'm after an LSD for my 318is but I don't know which one is best, after reading the wiki I know they came with an 4.10 as an option but is that the best one to get?
Thanks Dave
Best LSD for an IS?
Grrrmachine
- E30 Zone Wiki / Team Member
Depends what you want it to do. If you're a fan of racing around tracks then get a higher diff for better acceleration. If you want better cruising speeds with the occasional fast corner, get a 3.91.
Real question is, why do you want an LSD?
davelarge
Well the cars a daily driver so sounds like a 3.91 would be good.
I fancy an LSD because at the minute I've got a welded diff which is getting annoying because, 1 I don't drift and 2 it's destroying tyres, but I think if I swapped back to an open diff I would miss the ability to slide the car around abit so an LSD is the best of both worlds.
appletree
If you want to keep the standard ratio I have a very good condition rare torsen LSD for sale, just had an oil change and new bush.
Pm me if you are interested
davelarge
Another thing I was wondering was do I look for a small or medium case diff, as the wiki says the 325 is the only one with the medium case or do they all fit?
Medium and small cased E30 diffs. are interchangeable.
3.91 medium 188 LSD from a manual 325i sport or 325i touring, job jobbed!
