Twin rear caliper conversion / 4 pot brake upgrades
Quaser
Post Mon Jul 01, 2013 6:07 pm
Opinions on this pls guys
http://www.ebay.co.uk/itm/Adapter-to-co ... 580wt_1170
I don't think its to convert drum to disc - but even so, im more interested in the twin caliper setup
HairyScreech
Post Mon Jul 01, 2013 6:41 pm
Its so you can run a hydraulic hand brake to a full set of calipers, by all accounts the "wrong" way to go about initiating a drift.
Quaser
Post Mon Jul 01, 2013 6:49 pm
Ahh - that's a bit crap.
So is there anything bolt that I can get to upgrade my front/rear brakes and still fit under the 15" bbs's?
Jimbob
Post Mon Jul 01, 2013 6:50 pm
Yeh the WMS stuff fit under 15" I think.
Quaser
Post Mon Jul 01, 2013 6:53 pm
yeah - I forgot to mention something that doesn't break the bank either - lol
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jul 01, 2013 7:34 pm
"Cheap brakes" is an oxymoron.
zaust
Zone day release
Post Mon Jul 01, 2013 7:47 pm
There are plenty of different set up's you can use, depends more on your pocket than anything. Also you are better off stating your needs/ reasons before taking advice.
M30 Tech 1 Touring on gas.
Quaser
Post Mon Jul 01, 2013 7:51 pm
Need is m52 conversion in a cab - I was looking at 4 pot rx7 conversion as an option, and want options similar pls - I also heard about using e36 c&a pliers and 540 rears for the back
zaust
Zone day release
Post Mon Jul 01, 2013 8:15 pm
If that's your need then I would be looking at well working e30 standerd set up with uprated disks and pad's, Concentrate on the front for stopping power. 4 pot WMS or AP with matching bells ane disks to fit under a 15" will set you back around 1200 either way.
BATTS91
Post Mon Jul 01, 2013 11:52 pm
HairyScreech wrote:Its so you can run a hydraulic hand brake to a full set of calipers, by all accounts the "wrong" way to go about initiating a drift.
Nout wrong with a hydro :) 100mph entry on the wand ...
Quaser
Post Tue Jul 02, 2013 7:38 pm
ok - changed the title of the thread, as I just missed out on the wilwoods for sale on here earlier today -
ive been reading about brake upgrades, and a few sites have suggested the mazda rx7 4 pots with corrado 280mm discs - theres a guy in America doing refurbed mazda 4 pots, with the adaptors, bolts and delivery for $360 - anyone on here done anything like this?
Quaser
Post Tue Jul 02, 2013 11:20 pm
and can this be right - m3 2 pot rear calipers for under £70 each?
http://www.ebay.co.uk/itm/BMW-3-Series- ... 793wt_1199
edit - i think im getting over excited by the pic - its just a generic pic advertising a caliper :(
Jimbob
Post Wed Jul 03, 2013 7:43 am
That's about right for a remanufactured caliper. You'd still need to track down the carriers which would more than likely mean you'd have to buy a whole set of calipers second hand anyway.
Duke137
Post Wed Jul 03, 2013 8:09 am
WMS brakes are epic, I have all four corners and they too much for the road 8O
Quaser
Post Wed Jul 03, 2013 8:35 am
Duke137 wrote:WMS brakes are epic, I have all four corners and they too much for the road 8O
how much are they?
Automaton
Post Wed Jul 03, 2013 9:45 am
This?
http://www.ebay.co.uk/itm/Adapter-to-co ... 1c33d98492
OR
http://www.ebay.co.uk/itm/BMW-E30-disc- ... 8977554%26
I have drums on my 316, and have ordered a fresh brake cylinder set and spring kit, so will put off conversion to later. Will have to change the arms and a whole bunch of things i guess.
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
Duke137
Post Wed Jul 03, 2013 10:00 am
how much are they?
In excess of £1200 for the lot when I bought them 1.5 - 2 years ago.
Here a couple of snaps of the rears:
Quaser
Post Wed Jul 03, 2013 10:51 am
thanks for the pics - i see that no carrier is needed for the rears, will try and find something that fits
Im gonna try to get an upgraded brake setup for around £600-£750 i think.
the front rx7 caliper kit works out to around £250 for refurbed caliper kit with pads & delivery, £70 for front discs, £90 for the braided lines, and maybe e30 m3 rears with bigger discs for now, until i find a rear 2 pot kit, and a e32 master cylinder - should have me stopping much better then i do now :)
Duke137
Post Wed Jul 03, 2013 11:05 am
For a road car Quaser the rears are overkill, seriously. If you had WMS up front, that would be within your budget. You could use E30 Touring rear calipers, as the WMS System is only 0.3% bigger apparently but in fairness a good clean down on the Cabby rear set up and jobs jobbed.
I find my cars braking very off/on but there has been zero brake fade on mine with a bit of spirited road use.
Failing that DanThe maybe able to offer a bracket set up for 540i brakes like his Chromie has for smaller budget but I am not sure about the minimum wheel size?
The WMS is bolt in, fits under 15" BBS, tried and tested and within budget. Seriously, fire a PM to Keri? He can be slow to respond sometimes but he is a good guy.
The fact these slot under BBS 15" is one of the main reasons I went for the WMS variant.
HTH
