under bonnet sound foam
moggie
anyone got any tips on products to use to get the old glue off the underside of the bonnet
Grrrmachine
- E30 Zone Wiki / Team Member
Toyota brake cleaner IIRC. But ideally you'll want the bonnet off the car.
Topblag
You need to get it all off, I saw what happens if you don't remove the old stuff completely and add a new one, it doesn't stick properly
I used winns brake cleaner and it worked fine. Make sure you are working in a well ventilated area, it's strong stuff.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Cloggy Saint
Andy325i
I'm guessing Some Tar and glue remover would work well?
moggie
i will get some brake cleaner tommorow and have a go,yes you are right it doesnt stick on the old glue which ive just found out the hard way
pukar
jamlid
Can you get replacement foam from the dealers? (If so, how much?)
Yes you can, about £40
zd3bx
Really? That's pretty cheap and I didn't know they were still selling it..ImysE30 wrote:Yes you can, about £40
Any exact part number? I can't find anything specific myself...They are not listed in the parts catalogue.
Gavla
Just bought one £43.63 incl VAT and delivery from Cotswolds.
moggie
upvc solvent cleaner works a treat for getting the glue off by the way.
pud1
..got an original kit from main dealers, scraped off the old with a decorators scraper, used some sandpaper on what was left, got a can of spray glue, applied it to the adhesive on the foam as if there was none there already, banged it on... solid. Wont come off in a month of Sundays.
polsta
pretty sure when i got mine the other week it had a sticky side, although i didnt fit it, makes the car look so much nicer with new foam
