number plate delete panel
DMW
Post Fri Mar 29, 2013 6:39 pm
due to having 2 number plates cracked due to numpty drivers using my bumper as when to stop reversing when parking, iv moved the plate to under the bumper, is their a panel that covers the holes left behind or do i just fill them in and smooth it out.
my fleet
3 e30 tourings 2 316i 1 325i
E30 318i red coupe
e36 328i sport silver
e36 320i cab black
e39 540i black
e31 850i
macas
Post Fri Mar 29, 2013 6:54 pm
You must be bloody unlucky to have had two number plates cracked!...i would leave it where it should be,it looks shit where you have put it.....
No offence intended,just my opinion :D
DMW
Post Fri Mar 29, 2013 6:58 pm
macas wrote:You must be bloody unlucky to have had two number plates cracked!...i would leave it where it should be,it looks shit where you have put it.....
i like it :mad:
my fleet
E30 318i red coupe
e36 320i cab black
e39 540i black
e31 850i
verde
Post Fri Mar 29, 2013 7:06 pm
Get a metal pressed plate?
Raise hell praise Dale.
Post Fri Mar 29, 2013 7:10 pm
US spec. E30s use the same bumper as the rest of the world, but different rubber strips, with a separate bumper mounting plate. I've no idea exactly what they look like, or if they suit your needs, but possibly worth looking into.
Seems strange to me as well that you've had damaged number plates. One of the plus points of E30 bumpers is that they can be used to 'enlarge' parking spaces, if you find yourself blocked in by some inconsiderate idiot, and I've used this facility a few times over the years without ever damaging the plate.
DMW
Post Fri Mar 29, 2013 7:13 pm
Brianmoooore wrote:US spec. E30s use the same bumper as the rest of the world, but different rubber strips, with a separate bumper mounting plate. I've no idea exactly what they look like, or if they suit your needs, but possibly worth looking into.
have verrrrrry bad drivers wear i live :cry:
my fleet
E30 318i red coupe
e36 320i cab black
e39 540i black
e31 850i
bar2
Post Sat Mar 30, 2013 10:48 am
I would rather have them hitting my reg plate than my bumper
pukar
Post Sat Mar 30, 2013 1:17 pm
if you fill and smooth, then a slight hit will cause that to crack and look a mess.
put the plates back , but use some high quality foam sticky pads, this will redoce the chance of a plate cracking and also ha a bit of give for those idiots
Cloggy Saint
Post Sat Mar 30, 2013 1:34 pm
I consider that good going. Replacing my number plate is almost a monthly occurrence, usually damaged by tossers with tow-bars who will probably never tow anything in their life :x
