Hi,
I am placing an order for common nuts and bolts that are used on the E30. Seeing as some have been a royal PITA to remove as they had been some what rusty I am replacing any that get taken off with new.
So far I have got the following list, is there any other commonly used sizes that are worth getting:
M6, m8, M10, M12 hex nuts
M8, M10, M12 nylock hex nuts
M6, M8, M10 washers, crush washers
Any others that would be useful?
Common nuts and bolts sizes on E30's
Rtaylor2208
Topblag
I'm sure Mr Moore will be able to help.
I'd be interested in building up some spare nuts and bolts Russ, to help in managing my fleet. Any chance of adding to your order or getting the details so I can place my own order ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Rtaylor2208
Just using a local hardware shop in Ayr, they stock pretty much everything and can purchase in multiples of 10. Most sizes are 10 for £1 as well which is a bonus.
Shaheenk
Torx-countersunk screw ISA M8X18
Hex Bolt with washer M6X16-SB-Z3-2
Hex Bolt with washer M6X20-SB-Z3-1
Hex Bolt with washer M6X16-Z3
Torx-bolt with washer ISA M6X16
Hex Bolt with washer M6X12-Z2
Self-locking hex nut M8
Grrrmachine
- E30 Zone Wiki / Team Member
You'd be amazed at the sort of stuff the Wiki has
http://www.e30zone.net/e30zonewiki/inde ... _and_Bolts
Rtaylor2208
Mr Grrrrr, never new that existed. Thanks very much.
- **BANNED**
Be aware that some bolts have differing thread pitch,diff mounting bolts for example are M12 1.25 pitch,your local hardware store's offering will be 1.5 pitch thread.(think I have that the right way round!)
Caliper mounting bolts are another with this issue.
These oddball one's are,of course,available from your local friendly stealer.
I tend to automaticaly replace things like ARB mounting bolts and similar with stainless steel nuts and bolts,then they will come undone next time!
Youth is wasted on the young.
maxfield
Diff bolts are M12x1.5 and a standard M12 is 1.75, so you were closedaimlerman wrote:Be aware that some bolts have differing thread pitch,diff mounting bolts for example are M12 1.25 pitch,your local hardware store's offering will be 1.5 pitch thread.(think I have that the right way round!)
We keep a hell of a lot of nuts and bolts in stock at work and its awesome, especially on the late nights.
I'f persobally just get a selection of M6, M8, M10 and M12 nuts/bolts/washers. Certainly very handy.
Rtaylor2208
Arb nuts are my nemises at the moment. Trying to get the drop links off the bar is proving some what difficult.
Topblag
Fairy liquid my friend.Rtaylor2208 wrote:Arb nuts are my nemises at the moment. Trying to get the drop links off the bar is proving some what difficult.
- **BANNED**
Assuming that you are fitting new drop links,then Mr Angle Grinder is your friend!Rtaylor2208 wrote:Arb nuts are my nemises at the moment. Trying to get the drop links off the bar is proving some what difficult.
At the front,the U bracket has a splined stud that passes through the bracket and the wishbone,this usually breaks for me,it is just about possible to replace the stud with a bolt,but it may need it's head trimming to allow the drop link to fit properly.New U brackets are not expensive,but it's usually the last job late on Sunday night!
Rtaylor2208
Yep new drop links and bushes. Typical that my angle grinder packed in as well.
Fortunatly the wishbone bolt \ nuts came off no problem.
Colin I assume you mean fairy liquid for doing the bushes?
