gents;
i'm chaning the stat and water pump on my e30 318is, got the stat out but alas i cant get the viscous fan off.
can i assume it is left hand threaded? ive got the correct tool but all i'm doing is either tunring the engine over or the belt is slipping. is my only option to use a hammer and punch and try and knock the nut round??
any tips?
m42 water pump, viscous fan question **now with pic**
lhd220turbo
gooner1
- Out humping Reindeer
long 32mm spanner and a hammer hit anticlockwise will get it off.
+ a yard full of scrap turds
lhd220turbo
glad im changing it
occasionally the temp gauge would go slightly over half way if stationary then go down to normal once moving again. Not only are the fins breaking up the bearings are stiff too
lhd220turbo
changed this last weekend but could not get the system to bleed the temp started rising again & no heat through the airbox so switched it off & left the cap off the rad in the hope it would bleed itself
come to give it another go today and its bled itself so job jobbed
