Engine refresh
jonny323i
Post Sat Feb 02, 2013 6:11 pm
I will be fitting another m20 into my touring soon and id like to refresh any seals/gaskets that can leak prior to fitting can anyone give me a list of what they would replace prior to fitting.
I will definatly be doing the sump gasket, rocker, crank seal and inlet gaskets and the timing belt.
And if i decide to get the injectors cleaned who is recomended and roughly what cost
Touring for life
Cloggy Saint
Post Sat Feb 02, 2013 6:13 pm
I'm doing the same at the moment with the addition of a new clutch. Injectors to injectortune here on the zone, ten quid per injector.
Post Sat Feb 02, 2013 8:05 pm
Whats wrong with the engine thats in there mate ? apart from the slight hunting at idle which seems to be standard issue on a lot of M20's it sounded pretty sweet when I saw it last ?
jonny323i
Post Sat Feb 02, 2013 8:17 pm
Theres a few little issues but the engine iv got my hands on is from a low mileage sport which i know ran perfect.
Mine needs a clutch,water pump gasket as it leaks and a general tidy up this was cheaper than buying the clutch and the replacement comes with a near new clutch so why not lol.
Touring for life
BenHar
Post Sun Feb 03, 2013 1:08 pm
Cam shaft oil seal and D seals in rocker cover.
Ben
