Painting tech 2 kits
verde
Post Thu Jan 31, 2013 10:38 am
Plastic primer oder regular primer? Wer getting very close now...
Not sure on what colour to use either but I shall contact autopaint and ask
Raise hell praise Dale.
Post Thu Jan 31, 2013 10:53 am
You need "Plasticiser" for the paint to make it flexible.
Nato_e30
Post Thu Jan 31, 2013 11:02 am
If its bare plastic (ie no paint on what so ever) use a plasticiser - standox make a good one and youl need one even coat, then a wet on wet primer (if your not planing on rubbing down between coats) if you plan on wet flatting the primer use a two pack primer, if you decide on the 'wet on wet' approach one even coat not to heavy ,check out the recoat time on the tin then go straight on with the desired top coat.
verde
Post Thu Jan 31, 2013 11:04 am
It has paint on it. Its alpinaweiss, its been fitted before. Will I get away with flattening it, priming it then just painting, or plasticiser still needed?
Nato_e30
Post Thu Jan 31, 2013 11:22 am
Ok its easy for best results then flast down with 1000g wet and dry then give it a go over with a grey scotch pad to get in all the gaps ect (your aim is to get rid of the shine and make it matt), aslong as you dont go through the paint you can put colour straight on. You only need to prime it if bare plastic or bere filler is visble :)
Primer is just a barrier to stop reaction and to make the paint adhere to the repaired area or bare plastic/filler or metal. If the panel is painted already its a piontless exercise priming it :)
Nato_e30
Post Thu Jan 31, 2013 11:25 am
Note how just repairs are spot primed... this is ready for paint, I did a colour change on mine.
verde
Post Thu Jan 31, 2013 11:53 am
Excellent thanks nato. I love that colour you chose, certainly one of a kind
Nato_e30
Post Thu Jan 31, 2013 1:18 pm
No probs :) its going battleship grey now ;)
verde
Nato_e30 wrote:No probs :) its going battleship grey now ;)
Good god man, do you own a spray shop?
Nato_e30
Post Thu Jan 31, 2013 7:02 pm
Erm yes lol,
polsta
Post Thu Jan 31, 2013 7:09 pm
you doing it yourself verde ?
this cars gonna be a ghetto superstar :D
just make sure you get the prep perfect, although my kit was nice enough ,when i saw it last week hed taken it right back got rid of all the silver and some spots etc on it, im guessing where hed filled in some deep chips and marks to get it smooth, its all in the prep
Nato_e30
Post Thu Jan 31, 2013 7:12 pm
^man speaks sense. :cool:
Nato_e30
scott180gtb
Post Thu Jan 31, 2013 8:12 pm
Nato_e30 wrote:Image
This is a daft anal question but would masking up the gap from the sill to the floor and masking up the wheels etc effect the paint job?
The reason for this is to stop over spray under the car.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Nato_e30
Post Thu Jan 31, 2013 8:37 pm
No pal, I do that, when I do repairs I generally clean the crap of behind the wheel arch and behind the sill lip air blow it all aswell so no crap gets dislodged and bag the wheel up then I back mask it of the back of the sill and wheel arch. Stops that nasty over spray going under the car... if using a spray gun/compressor a bit of a tip I wet the floor under the car, not a massive puddle! The overspray sucks to the floor and it wont blow particals of the floor into the paint
verde
Post Fri Feb 01, 2013 8:13 am
polsta wrote:you doing it yourself verde ?
Iv been airbrushing for years, painted bmxes, odd bits and pieces round the house so fuck it, il try a car...have a go hero. I know its not going to be a great job but itl be better than what it was before. Heavily faded with no laquer on the roof bonnet or boot. As you say its all in the prep. Been taking our time making sure its all done proper
