Guys
Jamboree
Post Fri Jan 25, 2013 8:40 pm
I maybe buying my first e30 tomoz could you give me advice on what to look for please can you do a visual check on the cam belt rust areas to look at etc. when driving what to listen for etc. your thoughts will be most welcome your thoughts fast please as I havernt a level head at the mo excitement I guess cheers.
Post Fri Jan 25, 2013 8:49 pm
what model and engine size mate ?
snakebrain
Post Fri Jan 25, 2013 8:50 pm
Go and read the Wiki!
ajay
Post Fri Jan 25, 2013 8:56 pm
Don't do it!
popey7676
Post Fri Jan 25, 2013 9:01 pm
Where are you viewing this turd?
shedrool83
Post Fri Jan 25, 2013 9:31 pm
Check everywhere for rust, inner and outer rear arches ,scuttle ,battery tray,bulkhead,jacking points to name a few .
Basically rust is a killer on these mechanical faults are just bargaining tools in my book and fixable.
Post Fri Jan 25, 2013 9:44 pm
ajay wrote:Don't do it!
Jamboree
Post Fri Jan 25, 2013 10:10 pm
It's a 1988 325i e30 with only 66 thou on the clock that's what I drawing me two it the inner arches look pretty solid as the underneath spotted a small hole under seat body work needs some attention but with only 66 thou on the clock it's got to be worth a crack hasn't it more thoughts helpful ones please
Post Fri Jan 25, 2013 10:12 pm
it's a 325i at least .unkown < model or whether he's from Devon !
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Jan 26, 2013 8:32 am
Mileage only means something on cars up to 10 years old. Over that, you're still going to have issues with leaks, wobbles and rattles as the rubber components start to break down. On a 66,000 mile car, I doubt any of the owners have bothered replacing any suspension or steering rubbers, brake hoses or bearings.
Spend a good few hours reading the Wiki. Learn about all the mechanical parts, find out where the rust spots are and see what the common problems are. Start here:
http://www.e30zone.net/e30zonewiki/inde ... ing_an_E30
G-Bear
Post Sat Jan 26, 2013 9:11 am
Once you read through grrrmachine's link you'll probably want to read this..
http://www.e30zone.net/e30zonewiki/index.php/Rust
Also have a read through the topic titled M20 (325 engine).
Good luck..
M1k3
Post Sat Jan 26, 2013 9:12 am
magpie wrote:it's a 325i at least .unkown < model or whether he's from Devon !
:wave: Haha low blow.
Andyboy
Alpina Colada
Post Sat Jan 26, 2013 9:26 am
Grrrmachine wrote:Mileage only means something on cars up to 10 years old.
Not at all. A car with 66'000 that needs the usual work will have a value once finished. A car with 166'000 will not.
