Hi guys, rather than start 2 threads, thought it best to combine.
With the gearbox going in this w'end, i was considering lightening the flywheel a little after reading up about it. Its a 325 m20. I dont want it rattling on idle so wasnt going to go mad. All the threads talk about weight removal but i couldnt see any references to how much thickness to be removed, which i think my machinist would prefer to know rather than keep removing to weigh.
I will also be putting the pas fluid in. I'm sure i have read not to use normal pas fluid but something else? Its an e46 rack with Dan's kit.
Much appreciated if anyone can help with this
Christian
Flywheel and pas fluid
G-Bear
For pas fluid Dextron 3 I've read on here is the one go for. A new and better quality of oil (replaced Dextron 2) that's less likely to overheat.
As for the flywheel. Magpie on here has sold a few lightened ones recently. Perhaps pm him for info
Stonkin
Dextron 3, that was it cheers mate
5.5kg-6kg is a safe weight .
+ a yard full of scrap turds
Dexron 3 for fluid
5.3kg is even safer
The weight of the flywheel doesnt cause rattle, that will be your shagged gearbox
5.3kg is even safer
Stonkin
Cheers guys
Silverfang
Got mine at 6kg, rev's well on the 325i
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
