Hello guys.
Tried to start my car and it's taken a wee bit longer to fire... just a second or so but enough to make me think that's not right.
And now my alarm has went off 5 times this evening is it likely the two are connected is my battery dying?
I know this is cheeky but it's my Lexus not the e30.
alarm advice
Which Toyota have you got ?
Curr946
with the cold weather were getting I would put a bet on that its your battery
If your wife must learn to drive, don't stand in her way!
Battery - either dying or not charging properly.
bhaza
Yeah if it's a After market alarm usually they will trigger off if car battery is low, so really could also be alternator not charging battery. Best thing is to get the battery tested and see if alternator is charging battery.
Halfords, kiwi fit, independent garage all should do these test free of charge mate.
Hope this helps
Hope this helps
polsta
how do you know ? have you removed it all/looked at the unit etc ?318isPMK wrote:It's a'll standard OE
318isPMK
