Am i right or not?
What im getting with my ( 89 325i ) is start, revs flare but then sit at around 700rpm, once warmed they increase about 800/850rpm
AFM has been cleaned and contacts checked
TB has been cleaned, butterfly set etc,
All seals changed ( apart from the inlet manifold )
Blue sensor and stat changed
ECU swapped for a spare
Suspect ICV or ECU?
