Will BMW Mini wheels fit an E30 cab?
fastcarz464
I have seen a set of rims i like but they are for a bmw mini, size are 18", 215/35/18, will they go staight on, or require spacers etc or not go on at all, my car is a 92 e30 cabriolet, cheers guys!
chu346
IIRC the PCD is different, so they won't fit with or without spacers.
dasparkybad
are you shure
my mate has mini cooper wheels on his astra van doesn't that have the same pcd as e30
Demlotcrew
They will fit with spacers.
Andrew
Andrew
chu346
Sorry its the center bore which is different
E30: 57.1mm
Mini: 56.1mm
E30: 57.1mm
Mini: 56.1mm
fastcarz464
So will they fit then, where do i get the spacers from, how much do they cost and what type of spacers do i get, cheers.
Kos
10mm dedicated spacers and hub centric rings, longer wheel bolts all required
Lowm3
seen some vw's using them too 4 x 100 ..
but yep would need spacers... they do look good though.
