Met a guy who gave some weird advice...
Captain_Birdseye
Post Wed Oct 17, 2012 11:47 pm
He admired my car and told me that I should take the rubber grommet off the bottom of the accelerator pedal to make it go faster. What was he on about!?
Kos
Post Wed Oct 17, 2012 11:52 pm
:roll:
Try this experiment, take the intake boot off to the throttle body, get a mate to step on the throttle ( car doesn't have to be running to do this ) and see if how far the TB butterfly opens up.
Then decide if you need to remove the throttle stop
maxfield
You're looking at about a 10hp gain.
Post Thu Oct 18, 2012 12:04 am
Was his name Wallace, by any chance?
Post Thu Oct 18, 2012 6:42 am
you can also add about 10bhp by giving it a wash
e301988325i
Post Thu Oct 18, 2012 6:47 am
Seriously, I got 10bhp when I fixed the WOT throttle function of the TPS!
I said:
e30topless said:
lock the wife in there
Post Thu Oct 18, 2012 8:23 am
Dont forget to fold the rear seats down
Kos
Post Thu Oct 18, 2012 8:40 am
DanThe wrote:Dont forget to fold the rear seats down
What you want to do is rust the whole car into a stance sport lightweight, that's worth about 10p
George
Post Thu Oct 18, 2012 8:46 am
This
Captain_Birdseye
Post Thu Oct 18, 2012 4:42 pm
:mad: I emptied the ashtray, that gave a boost. :mad:
kangman
Post Thu Oct 18, 2012 5:14 pm
rumour has it that if you put the sun visors down it knocks off 2secs from the 0-60 time. But only on the 320i & 325i non sport models
BATTS91
Post Thu Oct 18, 2012 5:18 pm
I heard fitting a new flux capacitor release valve does wonders to an old m20! winkeye
greg124
Post Thu Oct 18, 2012 5:21 pm
I haven't got a rubber grommet behind mine.
Got a kick-down switch instead. I have a sneaking suspicion that removing that might just make it even slower... :(
Schadenfreude - the German's haven't got a word for that.
Post Thu Oct 18, 2012 6:38 pm
The advice given to the OP isn't necessarily without foundation. I cured my 18 year old's 'faulty clutch' yesterday by removing the doubled up floor mat from under the pedal, and if the throttle cable isn't adjusted properly, and is slack, a bit more pedal movement might just open the throttle a little more.
Kos
Post Thu Oct 18, 2012 9:07 pm
Fucking hell Brian :D
Hardly the right thing to do, im amazed you in a round about way suggest it. The fact here is with a correctly set up throttle cable removing the stop will gain nothing
I've several cars loose power from a slack throttle cable, even as much as 30hp on an m635csi
G-Bear
Post Fri Oct 19, 2012 8:06 am
I got my ears pinned...
Nobby_N
Post Fri Oct 19, 2012 8:13 am
G-Bear wrote:I got my ears pinned...
The above only works in a cabriolet!
