Cheers soggy
M3 convershion
Soggy
Ayup folks, I've got a 325m-sport that I've done a e36 2.8 convershion on, it's prety awesome but it's started to smoke it's nut's off now so I've managed to source a 3.Ltr M3 engine/lum/ecu's and just wounderd if any one had done it, I'm going to strip the car over winter to a shell, and then have it fully painted, oh and sort any rusty bits of which I'm shore there's plenty, I believe the brake servo may be a bit of a problem? I all ready put a smaller one on for the 328 convershion and just wounderd if any one had any suggestions? One friend suggested getting a pedal box and doing away with the servo all together? Any help would be greatly appreciated.
Cheers soggy
Cheers soggy
Nobby_N
Where you from mate? England? Hi btw
Soggy
Well funny, yer England, Manchester
- E30 Zone Meets/Events Team
Plenty of guys have done the conversion.
All in here
http://www.e30zone.net/modules.php?name ... forum&f=58
All in here
BATTS91
From what i hear you dont want to use a pedal box/ servo delete on a road car im sure a couple of guys here have tryed and said its not advisable ;)
jmc330i
What servo have you fitted for 2:8 conversion?
Chances are it will be fine for the S50 conversion if you either mod the plenum or move the servo over closer to the inner wing.
Either way, it will still be tight for space with S50 plenum. And as above, a pedal box isn't recommended for road use.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Soggy
I used a Clio servo, I was thinking of maybe a remote servo? I'm going to start striping it soon so I might just offer it up and see just how tight it is.
jmc330i
You won't need a remote servo, and that's quite a lot of work. I used the slightly larger Golf servo (in the standard position) and modded the plenum.
If you move the Clio servo over, I expect you would only need to remove a small bit of the plenum corner, if any at all.
James
'91 325i Sport
'91 325i Sport
Soggy
Yer I think it would be best to offer it up first and see how much room there is, if I have to move the servo over it shouldn't cause a grate problem as I will have all the trim out anyway, I take it you have done the convershion?
jmc330i
Yeah, about 4-5 years ago. Sold it a couple years ago though
Moving the servo over isn't difficult. It gives enough room for the standard E30 servo to be used with your current conversion, so coupled with the smaller servo, should be great help trying to get S50 plenum in.
Have a look through the engine swap forum, the info is in there somewhere.
James
'91 325i Sport
'91 325i Sport
