Restoration painting or anodising
polsta
Post Tue Aug 21, 2012 1:49 pm
Ive found a local company that is going to dip then re finish all the fittings from my car-nuts,bolts,screws,brackets etc, il get some sort of rust proof finish hopefully and they have said theyl come back like new
but im also thinking- the fuel lines cover inside rear arch, head lamp holder unit things, and the head lamp rings- do you think they would benefit from the same process ? rather than blasting and painting, dipped then then some sort of smooth black anodised rust proof finish for the fuel cover and head lamp unit, then some sort of silver/chrome finish for the rings ?
when brand new were the head lamp rings a silver painted or a chrome finish ?
Post Tue Aug 21, 2012 1:53 pm
Head lamp rings are not expensive, they come with a powder/plastic coating and generally last very well.
When you say 'dip' what do you mean exactly? If its just an acid cleaning dip you wont get the results you would from sandblasting, more so if any parts have rust on them. Anodising and chrome plating is a much more expensive process and the prep work is what costs
Kedge
Post Tue Aug 21, 2012 1:56 pm
Doesn't an anodised coating scratch off fairly easily as well?
Instagram - Kedge85
polsta
Post Tue Aug 21, 2012 2:07 pm
i dont think so kedge, its just finishing metal and all sorts of coats can be done,i presume some more durable/rust proof etc than others
basicly- i went to a fittings place today with a load in a box, he looked at them and said they are not too bad and would be expensive to replace them all, most anyway they do not have as are a bmw custom fitting part, and that he has just restored a daimler himself and used these guys for his old fittings, he pointed me in the direction of them, said they will dip them to remove the crap and re finsh them and theyl come back like new, they charge by weight and estimated a £10/15 cost for the lot
http://www.macrodevelopments.co.uk/
, the other parts that are painted i mentioned, was just an idea on top of that , ie instead of blasting and powder coating the filler neck and head lamp unit, if they could dip and anodise them in a similar durable finish ?
Post Tue Aug 21, 2012 2:16 pm
Looks like a proper company, as long as they do a proper rust removal process before any coatings are applied you wont have a problem, you need to be careful though as a lot of places will just dunk them in a quick cleaning acid and the coatings wont stick properly, they will flake and rust through again after the first winter
snakebrain
Anodising does wear off, especially if it's on a surface that will experience friction with another surface. Ask anyone who owns a 5 year old Maglite..
It's best used on aluminium. I'm not even sure that you can anodise steel?
polsta
Post Tue Aug 21, 2012 2:21 pm
i have no idea hence the thread, but read the different finishes they do, and have pictures of screws and bolts there, so im sure they would have something suitable
the 65 odd year old fella who told me to go there, was i presume the owner of this shop, so he must know what he is on about look what they specialise in
http://www.cpfastenings.co.uk/
polsta
Post Tue Aug 21, 2012 2:27 pm
all these sort of bits is what i want done, so its either that or new from bmw
polsta
Post Tue Aug 21, 2012 2:35 pm
DanThe wrote:Head lamp rings are not expensive, they come with a powder/plastic coating and generally last very well.
s
i think they were £20 odd each plus vat when i enquired last year- not cheap really when its nearing a ton !
i have a spre set here anyway, dependign on price and i take the fittings to the above place, i might just take a set and ask what they can do if they can get a real durable finish and maybe something chrome looking ?
goosiegander
Zonegoose
Post Tue Aug 21, 2012 2:54 pm
Google aerocoat, they do chrome in a can for the rings, generally wheel refinishers and based in Norfolk, website is well worth a look,
Rich320I
Post Tue Aug 21, 2012 2:59 pm
is it not possible polsta, to derust those bits using the method Brian Moore detailed on here (electrolosis) and then get them coated. at least youd know the derusting had been carried out then.
snakebrain
Post Tue Aug 21, 2012 3:01 pm
polsta wrote:all these sort of bits is what i want done, so its either that or new from bmw
http://www.bmminiparts.com/Search.aspx
Loads on here..
polsta
Post Tue Aug 21, 2012 3:17 pm
Rich320I wrote:is it not possible polsta, to derust those bits using the method Brian Moore detailed on here (electrolosis) and then get them coated. at least youd know the derusting had been carried out then.
isnt that what that company would do ? look at their website,im sure they would do that ?
Rich320I
Post Tue Aug 21, 2012 3:21 pm
yeah mate looks like thats the process they undertake,
i was just thinking out loud, as others have mentioned if theres any rust left then it will soon come through the new coating.
and im abit tight fisted so was thinking it may be cheaper to do it yourself mate :)
polsta
Post Tue Aug 21, 2012 3:35 pm
well look at the website cpfasteners and what they sell, the chap in there looked at mine, told me to take them there theyl bring them up like new and charge £10/15 for the lot , surely hel know what hes on about as he sells fittings himself and mentioned the daimler, he also even knew things (if true or not useless fact of the day ?) that bmw made all fittings themself in germany until 1988 and afterwards they were produced in various countries all over the world, i think also some of these fittings are nla like the rear bumper rubber trimm clips for pre facelift ?
Rich320I
Post Tue Aug 21, 2012 3:39 pm
ha even im not that tight, i thought it would be alot more £ to get them dipped and recoated, good price then mate if thats the sort fo money it would cost.
that is a most interesting fact RE: the fixing and fastenings, should i find myself in a OEM BMW related pub quiz (sure they pop up from time to time) at least il know one answer :)
hennabm
Post Tue Aug 21, 2012 3:48 pm
On the earlier car a number of the parts and nuts/bolts etc were finished in yellow passivate.
The later cars were finished in a zinc type passivate.
I've had a few parts re-passivated over the years and to maintain their durability I have sprayed them in 2pack lacquer.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
polsta
Post Tue Aug 21, 2012 4:10 pm
would zinc plating be similar ?
from their website-
Zinc is primarily used as a coating for steel and provides excellent corrosion protection, although it can be plated onto other metals.
Thicknesses of up to 25 microns are normal and passivation treatments make the plating resistant to finger marking, while also providing a good base for painting.
The passivation finishes include Clear, Colour (iridescent), Black and Olive drab.
hennabm
Post Tue Aug 21, 2012 6:37 pm
Hi
yes zinc plating is the same. You will find most nut/bolt suppliers will do bright zinc dull zinc and what looks like a chrome finish. The yellow passivate finish is very hard to find.
I have bought just standard metric set screws and nuts in yellow passivate in a box from Frosts but the more specialist type like you are wanting, I have to buy in zinc and then take to my passivater friend.
I use a place in Hull called Alliance Electro plating.
For the bits you show I would buy new from BMW as it will probably be cheaper than cleaning and recoating the ones you have.
HTH
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
fearlessphil
Post Tue Aug 21, 2012 7:07 pm
i little know trick that i have used several times to unbelievable effect is apple cider vinager! soak the parts for 24 hours then wash off with warm soapy water bingo Not a apeck of rust on them at all! they are quite pourus after though so heat em up till cherry red with a blow lamp then dip them im motor oil (oil blacking) they come out all nice and black and rust resistant! simples!
polsta
Post Thu Aug 23, 2012 10:48 am
awsome tip il keep that in mind as a back up after taking them to that company 1st and see what they say
alan1272
Post Thu Aug 23, 2012 8:32 pm
why not have a bash at it yourself? saw some chaps using a kit similar to this on their rally build, with very good results.
http://www.gaterosplating.co.uk/Zinc-Plating-kit.php
polsta
Post Thu Aug 23, 2012 9:01 pm
homebrew zinc plating kit £60, a trial and error non proffessional go at it and hours of messing about and mess, vs a £15 proffessional job quater of the cost and no time or messing about ! although if was doing lots and regular it would be worth investing and learning it
alan1272
Post Thu Aug 23, 2012 9:59 pm
yeah there is that, but it's interesting innit :D
scjimbo
Post Thu Aug 23, 2012 10:43 pm
http://www.thisoldtractor.com/gtbender/zinc.htm
I might have a bash at this with the power supply I bought for the electrolysis bath.
scjimbo
Post Thu Aug 23, 2012 10:50 pm
Mind you real heros go for cad plating.
