Hello all,
I've changed the cam cover gasket on the I.s together with the gaskets for the plugs. Luckily I did some research as to what was involved with the job before I refit and I've read so many horror stories about stripped threads due to over tightening. If I hadn't read up I would have probably overtightened the bolts too. Now I've got all the bolts back In and they have all threaded in fine which is good but I darent tighten them with a wratchet just in case I knacker a thread, so far I've tightened them by hand with just the extension bar and socket but don't know if it's enough to seal
Your advice please
M42 cam cover bolts
DHFiS
Mine are only hand tight and I havent had problems. Might be worth putting a bit of thead lock on them but the rubber round the bolt seems to stop the vibration loosening mine.
jimbom30cab
- Tech 1 freak
yer i think you have done it enough, give it a run and it should not leak
if you're going to do much work on cars, you should really invest in a torque wrench, but as a general rule, the correct torque for a nut or bolt is that which you can apply with one finger hooked over a 'standard' length spanner for the size of fastener in question.
No thread lock required, and FAR more damage is caused on vehicles by fasteners being overtightened than under tightened.
you can give it a nip with 1/4 " ratchet ,just a quarter turn and it's sealed .
all this talk of finger tight on an m42 screamer.They will rattle loose and leak leaving you to clean it all up and if your on a long drive and don't notice the smell of burning oil , bang goes your Donk .
fire it up and check for leaks before driving,give it some revs when warmed up as we don't drive around on tick over do we .
NEXT!
NEXT!
+ a yard full of scrap turds
Emm3
Got a torque wrench Brian but I wasn't sure on using it as I thought the threads may have weakened over time with heat and may not be as strong?Brianmoooore wrote:if you're going to do much work on cars, you should really invest in a torque wrench, but as a general rule, the correct torque for a nut or bolt is that which you can apply with one finger hooked over a 'standard' length spanner for the size of fastener in question.
Emm3
Well I had to use the wratchet as the hand tightening technique did not work started the car and it burnt oil like mad as the plug gaskets were not sealing due to the bolts between the plugs not being tight enough, the oil dribbled down onto the plug and then into the bore. I did them up until I could feel the resistance, fired the car up and voila no leaks and no oil burning. I've removed the throttle body heater plate and all the nasty pipe work the car idles so perfect now
appletree
Even in the worse case of one stripping you can buy a helly coilset as I had to as mine had 3 stripped threads when I got it.
