Hi, I have a 318i m40 and have recently replaced the rad cap (expansion tank cap). Now though I have noticed that when I squeeze the radiator hose air comes out of the rad cap then sucked back in when I let go. Quite freely, no pressure required at all.
Basically, is this normal? I don't remember noticing this before.
Dan
Quick question - radiator cap issue
Barx325i
sure it's the cap? if so, check it's freely screwing down & there are 2 O rings present.
secondly make sure it has a yellow part on the inside - these are the recall version.
if you're not completely sure, check the cross-head bleed screw, right next to the cap..
DanTheDoc
Hi,
Thanks for the reply. It's definately the cap. There are two o-seals present and it screws down tight. It's the yellow version too as I only replaced it about a week ago because I don't think it was before.
For info, the bleed screw is fine.
mani
could need a washer
Billwill
I just checked the cap on my M40....fairly new from BMW.
It has the yellow plastic inside section and has "140" stamped on it.
Has two O rings and a large black rubber washer that seals tightly on the inner rim of the bottle when screwed down tight.
Maybe they have given you a faulty part?
DanTheDoc
Thanks for checking yours.
I'm starting to doubt my radiator to be honest, I've borrowed a rad cap from an E46 (same cap, different pressure "200") and put that on. Screwed it up tight but can still squeeze the hose easily expelling air out of the rad cap.
I put my hand over the hole and squeezed the hose, no leaks at all but with a cap on air flows freely. I'm wondering if the thread is too long or tank neck too wide or something. Whatever it is, neither cap seals the system.
DanTheDoc
Just to confirm, if you squeeze either the in or out hose on the radiator, is air supposed to blow/suck from the radiator cap easily?
With the cap in place, air can enter reasonably easy, but you shouldn't be able to expel it.DanTheDoc wrote:Just to confirm, if you squeeze either the in or out hose on the radiator, is air supposed to blow/suck from the radiator cap easily?
DanTheDoc
Right, thanks. Something is definately up then because I can expel air incredibly easily by squeezing any coolant hose. I'm going to put my old expansion tank back on and see what that does.
Thanks everyone, I'll keep you posted.
Dan
Dan
DanTheDoc
Well, the rad cap turned out to be fine.
I put the old radiator back in and bled the system and all seems to be ok (with the exception of the original leak).
So, to sum up, got sent a faulty radiator. And you CANNOT get the coolant system functioning correctly when the radiator cap does not seal, it just pi**es out everywhere!
Thanks for the replies
Dan
Dan
