e30 318is
e30kid6
Post Sat Jul 14, 2012 9:41 am
Just bought a 318is, very cheap.
Very good condition, its needs the clutch bearing replacing by the sounds of it.
And was wondering what is the best affordable clutch you can fit to an IS. I've heard of people fitting a standard 325i clutch due to it being single mass?
Also, is the exhaust system the same as a 318i?
DHFiS
Post Sat Jul 14, 2012 5:35 pm
Dual mass flywheels are uncommon, does your car have A/C?
Exhaust is not the same as the 318i.
Andyboy
Alpina Colada
Post Sat Jul 14, 2012 5:45 pm
The flywheel, clutch and starter from a 320i will do just the job.
e30kid6
Post Sat Jul 14, 2012 7:28 pm
Thanks.
No A/C no.
Do you have to replace the whole starter motor?
Post Sat Jul 14, 2012 9:02 pm
you can change the small cog over to one from an m20 so you might as well just fit the whole thing .
