30m or 35m (lowering)
ameetgill1
Post Tue Jul 03, 2012 4:45 pm
guys whats the best and the smoothest options in terms of look, size and stability
Post Tue Jul 03, 2012 5:39 pm
either of those drops are good enough not to compromise the ride comfort,what shocks are you going to use ?
ameetgill1
Post Tue Jul 03, 2012 7:07 pm
http://venommotorsport.com/prod_categor ... versal=Yes
what do you recommend in the above?
will they both go over bumps and plus i am looking for 16inch alpina wheels so will they be ok.
G-Bear
Post Tue Jul 03, 2012 11:09 pm
Bilstein and H&R are a popular choice on here. If you go for Bilstein's whole kit (dampers and springs) they use Eibach springs which I think are said to be not quite as stiff as H&R springs.
I've got Eibach springs, they make for a sturdy ride but not too much of a bone shaker.
Have a floss through the below link, that should give you some decent info..
http://www.e30zone.net/modules.php?name ... os+lowered
ameetgill1
Post Tue Jul 03, 2012 11:32 pm
thanks for that i reckon il go for h and r. is there anything else i need like shocks or will the kit be sufficient
Morat
Post Wed Jul 04, 2012 12:54 am
Don't forget roll bars while you're there.
