Miris325i
Post
Mon Jun 25, 2012 1:10 am
Hi as a topic does anybody knows some1 who is able to do that...2guys already let me down, so pls only who can do it for sure
Thanks a lot
Miris
1988 327i M-tech II...stolen
1993 316i touring...V8 build
Green
Post
Mon Jun 25, 2012 1:19 am
Any local engineering place should be able to do it for you, have you tried that?
Miris325i
Post
Mon Jun 25, 2012 11:38 am
Green wrote:Any local engineering place should be able to do it for you, have you tried that?
Nope m8, i didn't think about that....whats a "diameter" of BBTB?
Miris325i
Post
Mon Jun 25, 2012 1:19 pm
Thanks Ian, yep i read that, but it doesn't say how much metal u can take off(have to find my old fooked BBTB and check it)...and £120 its quite expensive as i heard it should be done for £60-80.
scjimbo
Post
Mon Jun 25, 2012 1:57 pm
If you can post/pm me some pictures and sizes of what you want done i would be happy to give you a quote to do it for you as long as we have the kit here.
maggspower
- Turbo Farmer Tractor Driver
Post
Mon Jun 25, 2012 2:01 pm
The throttle can be taken out to 64mm. If you think £120 is expensive then don't look at this link:
http://www.ca-int.co.uk/products-Y2FyX2 ... kPTg=.html
And if you can get it done properly for £60-80 I say go for it.
There is alot of work involved, take the thing apart bore it to the correct size, then mill the slot in the spindle to accept a larger butterfly, next make a new butterfly using a custom jig so you can taper it the 4 degrees required (a throttle butterfly is not round), finally put it all back together while trying not to have a spring related eye removal situation
Miris325i
Post
Mon Jun 25, 2012 2:25 pm
maggspower wrote:The throttle can be taken out to 64mm. If you think £120 is expensive then don't look at this link:
Thanks for that!! Do u think they could use my fooked BBTB as donor?? picture follow
maggspower
Post
Mon Jun 25, 2012 2:27 pm
What is wrong with it?
Miris325i
Post
Mon Jun 25, 2012 3:17 pm
When i get my 2.7stroker i found out that BBTB is fooked. That spring on top of body came off (during the delivery must hit something hard or i don't know)...will find picture for better explain
Miris325i
Post
Tue Jun 26, 2012 4:13 pm
maggspower wrote:What is wrong with it?
That's wrong...i don't think its repairable...or is it?
[/img]
Andyboy
- Alpina Colada
maggspower
Post
Tue Jun 26, 2012 4:25 pm
Andyboy wrote:That's scrap.
Indeed
Dont throw it away though.
PMed
Kedge
Post
Tue Jun 26, 2012 4:32 pm
At leat you can salvage the butterfly and just get your other TB bored out for it to fit.
Miris325i
Post
Wed Jun 27, 2012 10:14 am
Kedge wrote:At leat you can salvage the butterfly and just get your other TB bored out for it to fit.
same thinkin
I just came back from post office, u should get that TB in 2days
