ok called bmw with my vin number to find out what diff i have as the tag is gone and this is what they told me
its I=47:11=4,27
anyone know what that is?
i have a 1993 - 318i cabby m40
thanks
what are my ratio's ???
gnrsoul
Duke137
4.27:1 I would say, unless it has been changed. You can also check the wiki
http://www.e30zone.net/e30zonewiki/inde ... fferential
Scroll down to the table at the bottom
Looks to be correct.
gnrsoul
need a replacement as myone is noices and whines and it p1ssing me off
redcar
Hi mate, 4.27 is what my m40 316i had, which I imagine is the same as what you would have on yours if it's also a manual.
Are you looking to buy a diff?
gnrsoul
yes looking around fora good priced one that does not have any noices or whines
47 and 11 are the number of teeth on the crown wheel and pinion gears respectively.
rich318i
there is a way to find out 100% what ur diff is a 4.27. turn the wheel 10 times and count the mount of times the input will turn 42.70 times, 100 turns of the wheel and the input will turn 427 times.
G-Bear
From reading through the above, I did a quick search to see if they can be serviced as mine is noisy and wines away. In doing so, came across this for sale on one of Magpies frags, if that's any help. It's 4.27...
G-Bear
e30-EVN
surely turning the output shafts once and counting the input turns would be easier.....there is a way to find out 100% what ur diff is a 4.27. turn the wheel 10 times and count the mount of times the input will turn 42.70 times, 100 turns of the wheel and the input will turn 427 times.
4.27 turns of the input will result in 1 turn of the out puts
A 2 door e30 with 8 cylinders, what could be better
This won't work with an open diff, since both rear wheels are unlikely to turn together at exactly the same rate. You would normally do this test with one wheel still firmly on the ground, so as to remove it from the equation, and this would result in the input shaft turning 854 (2 x 427) turns for 100 turns of the wheel.rich318i wrote:there is a way to find out 100% what ur diff is a 4.27. turn the wheel 10 times and count the mount of times the input will turn 42.70 times, 100 turns of the wheel and the input will turn 427 times.
