Pagid / Sachs / Bilstein or Bosch
Let me know your opinions and experiences
I wish you hadn't said that. I just ordered one for my M20B25DanThe wrote: I ran an LUK on the back of my M52B30 and it died quickly, slipped like hell after only a few hundred miles and a couple of laps of Oulton Park, Sachs lasted 3 track days before it started slipping
was that with the duel mass or soild fly ?DanThe wrote:You will get a Sachs cheaper than that from Matt/ECP on here
The Q&H might be worth the risk if you spend all your driving time tickling the throttle but I wouldnt fit anything less than a Sachs, I ran an LUK on the back of my M52B30 and it died quickly, slipped like hell after only a few hundred miles and a couple of laps of Oulton Park, Sachs lasted 3 track days before it started slipping
I've got the engine and box and the floor of my garage to do it. Based on the location of all the bolts on the gearbox, fook doing that in situPeteE30Tourer wrote:I'm beginning to think this is the next job for me. How easy is it to replace the clutch?
I replaced my clutch master and slave cylinders a few weeks ago...slave cylinder is easy but the master cylinder can be difficult to access...I have small hands but it really can be awkward on the RHD models with the brake linkeage and air-con hoses getting in the way.Gavla wrote:Apparently the cylinders are a fairly easy job, however the clutch is not for the faint hearted?
Exactly the same was said by a mate of mine that works at GSF.irish320i wrote:we sell all of the above and we see most warranty returns on the luk stuff followed by transmech but the transmech only fails on bigger cars never had any back on lighter cars
this.!! i fitted a brand new luk to the back of my m52b28, it is complete shite and has been that way pretty much from brand new.!I wouldnt fit anything less than a Sachs, I ran an LUK on the back of my M52B30 and it died quickly, slipped like hell after only a few hundred miles and a couple of laps of Oulton Park, Sachs lasted 3 track days before it started slipping
because how many time do you think the clutch has been used in the last 23 odd years?.... not something that i would see last that long to be fair. and the amount he charged you suggests thats just the type of thing one of these rip off merchants would say to someone to make the job sound like it was more difficult than actually was.. my slave took me 15 mins from the time i stuck the jack under the carWhy could it not have been the original slave?
Quite right, that is what he said, clutch fluid was like tar. He may have taken the mick a bit but I do have faith that he knows his cars. I will question him more about the time he takes do work next time I have to get the car to him. (hopefully not soon!)Brianmoooore wrote:I can think of absolutely no reason not to expect the slave cylinder to be the original one, OTHER than lack of maintenance!
On RH drive E30s the clutch fluid is contained in a separate reservoir from the brake fluid, and this is its downfall.
Which is actually Euro Car Parts as they have the same VAT numberBrianmoooore wrote:http://www.carparts4less.co.uk/clutch-kit
