Best way to dye the carpet?
redcar
Post Mon May 21, 2012 6:46 pm
Hello, my current 4 pot povo spec grey carpet is a bit dull, so i really want to make it black so it spices the interior up a bit.
What's the best way to do it? :D
Cheers.
suchy
True Zone Relic
Post Mon May 21, 2012 6:58 pm
Never tried it myself but can't believe dye would take properly as the carpets are a man-made material aren't they? Wasn't aware wool carpets were an option with an E30 :wink:
I know people have done it but how long it lasts or even how long it stays looking good is another question!!
redcar
Post Mon May 21, 2012 7:00 pm
suchy wrote:Never tried it myself but can't believe dye would take properly as the carpets are a man-made material aren't they? Wasn't aware wool carpets were an option with an E30 :wink:
Indeed, i was also thinking that. I think the 4 pot carpets might be nylon weave but apparently the 6 pot carpets are much smoother/softer so it might be worth attempting to dye a 6 pot carpet rather than the 4 pot carpet.
Are there any other differences apart from the material, to the 4 and 6 pot carpet?
Post Mon May 21, 2012 7:02 pm
Wet vac a half decent 6 pot/lux/touring carpet all ive done have come up like new and get rid of that old e30 smell :D
redcar
Post Mon May 21, 2012 7:11 pm
Alex wrote:Wet vac a half decent 6 pot/lux/touring carpet all ive done have come up like new and get rid of that old e30 smell :D
Is it much softer and nicer compared to the 4 pot carpet. Do you have any pics? :cool:
Jim320i
E30 Zone News / COTM Team
Post Mon May 21, 2012 7:13 pm
BATTS91
Post Mon May 21, 2012 7:22 pm
i have a 318is dont know if the carpet is diffrent from other 4 pots, but i went to my local paint shop and see carpet dye in an aerosol can works well sprays out quick i think i used 3 or 4 cans looks good and it stuck to the drivers side fut part were its not carpet :D
redcar
Post Mon May 21, 2012 7:24 pm
BATTS91 wrote:i have a 318is dont know if the carpet is diffrent from other 4 pots, but i went to my local paint shop and see carpet dye in an aerosol can works well sprays out quick i think i used 3 or 4 cans looks good and it stuck to the drivers side fut part were its not carpet :D
Cool, sounds good. Do you have any pictures :D
BATTS91
Post Mon May 21, 2012 8:12 pm
i can get some up for you tomorrow if you like ,
i sprayed the parcel shelf in satin black normal paint and it feels quite hard but the carpet with the dye still feels soft
Post Mon May 21, 2012 8:17 pm
Use this stuff http://www.valeterspride.co.uk/black-ca ... l-69-p.asp
Just get your carpet cleaned up and then do this outside as the fumes are epic. Use a plant spray bottle and wear gloves and just squirt away. A couple of coverings will see it tip top. It dries pretty quickly.
polsta
Post Mon May 21, 2012 8:19 pm
for parcel shelf use a carpet spray dye it comes up super
for the carpet- ideally youd want to get it removed then give it a good clean, the vanish spray can foaming carpet cleaner is great stuff, and lots of water and a wet vax if possible,leave to properly dry in the garden and vacum it- so its a nice clean base to start with , then dye with a spray carpet dye, give a few coats maybe
adit
Post Mon May 21, 2012 9:11 pm
turk "borrowed" my carpet dye and coloured his beige carpets in his gold rocket and they looked good when done
[quote="bss325i"]
spook
League two here we come !!!
Post Mon May 21, 2012 9:17 pm
Whos carpet dye?
Barx325i
Post Mon May 21, 2012 9:24 pm
redcar wrote:Are there any other differences apart from the material, to the 4 and 6 pot carpet?
The 6 pot carpet is quite a bit heavier, plus it's a better sound insulator. Depends if road noise is a concern, I go with the lighter 4 pot and it's not too bad but the 6 pot rug is noticably quieter
redcar
Post Mon May 21, 2012 9:45 pm
Thanks a lot for the help everyone...It's really cleared things up. Thanks for that link Lee, will order that when the time comes.
Interesting about the difference in the carpets.
So just one final question - 6 pot carpet or 4 pot carpet? :cool: I've never felt a 6 pot carpet so i don't know what it would feel like and if changing to 6 pot carpet would be worth it. Increased sound insulation sounds like a bonus though!
adit
Post Mon May 21, 2012 10:00 pm
the 6-pot carpet is the softer velour ("posher") type and is nicer
[quote="bss325i"]
redcar
Post Mon May 21, 2012 10:06 pm
adit wrote:the 6-pot carpet is the softer velour ("posher") type and is nicer
Ok cheers mate.
Gotta find someone willing to swap my super mint 4 pot carpet with their super mint 6 pot carpet now! :mad:
When removing carpet is it easiest to just cut around the heater box and dash as this saves removing the whole dash and heater box? If i do cut around the heater box and dash bit, will this be visible when the full interior is put back in the car?
Cheers.
Jim320i
Post Tue May 22, 2012 9:34 am
Much easier to cut it, but if you take your time, you can get it out with out cutting it,the pain in the arse is getting it back in. You'll have to cut around the steering column part at the bottom anyway unless you strip everything out 8O
If you do cut it, then it wont be visable when put back in aslong as you cut it nice and closeto the matrix box :cool:
If your looking for a carpet, I have a few here if your interested, send me apm and if I get a moment, I'll get you some pictures :cool:
redcar
Post Tue May 22, 2012 5:46 pm
Jim320i wrote:Much easier to cut it, but if you take your time, you can get it out with out cutting it,the pain in the arse is getting it back in. You'll have to cut around the steering column part at the bottom anyway unless you strip everything out 8O
Ok cheers for the advice.
Will pm you
adit
Post Tue May 22, 2012 10:07 pm
you definitely don't need to touch the dashboard when replacing a carpet redcar :wink:
[quote="bss325i"]
