Guys with roll cages!
aaronsmart
Im looking to fit a roll cage but wanted a full interior
How much work/modification would be needed to the interior or cage to make this work?
- Homo Hair
You'll have to cut stuff.
Motorhole
Your back seats would be useless if fitting even the minimum spec 6-point cage as per the blue book.
The harness bar running from left to right is not mandatory and you can get removable ones anyway. But the single diagonal brace is mandatory and would make rear seat access pretty much pointless!
andrew_baran
Looks like you'd have to absolutely butcher the rear seat bolsters to get the rear points on. Not gonna work IMO.
Hoobs
Best solution is a custom cage that can take interior into account. Likely to cost though.
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
2002
aaronsmart
Ok cheers guys. Luckily my uncle is a metal worker and welder who used to build rally cars. I guess I'll have to go custom!
verde
its crap they dont offer a middle ground cage. like they do full on race cages for stripped cars but im in the same boat. i want something ideally bolt in that will cover me, the front passenger and allow me to have the rear seats still in. i dont care if the car shape is perfectly held when rolled, i just dont want crushed to death if i have a drifting accident
Raise hell praise Dale.
steve_k
If all you want it for is look's then go for a weichers show/roll cage as they are designed to work without modification to the rear bench.
they range in price from £350 (half/rear cage) upto £1000+ for a full multi point show cage (mirror polished).
try tuner shop for those.
but if you are going by the blue book then it look's like you will have to go custom.
it's all down to budget & required use.
verde
does the weicher half cage give the driver protection? thats certainly all im bothered about. i wont be booting it with passengers anyway
steve_k
well from what I've seen of them online they have removable door bars.verde wrote:does the weicher half cage give the driver protection? thats certainly all im bothered about. i wont be booting it with passengers anyway
have a search online for them & you'll see what I mean.
Motorhole
Just be aware that with a show cage you might be taking a significant safety risk! Firstly, any rollcage, MSA, FIA spec or otherwise is a risk if it's not properly padded, especially without harnesses or a helmet as it's a very solid structure on which you can hit your head and flailing limbs on in an accident. Secondly, motorsport spec rollcage are manufactured from seamless steel tube or T45. Steel tubes not of the correct specification can split in an accident major impalage is the last thing you want!
harry_p
why would you want a cage plus rear seats?
to have anyone actually use the seats with a cage surrounding them would be increadibly dangerous. so if you have seats that are no longer useable you may aswell lose them all together.
a 'show' cage is exactly that, they offer virtually zero chassis stiffness, and virtually zero impact protection, but they do place nice hard metal bars close to your head.
probably one of the most stupid and pointless things ever invented.
cheers,
harry
harry
verde
I dont wanna jack this guys thread. Im after a car with all the seats in i can buzz about with the mrs and a couple mates in reasonable comfort in. On the weekend or when alone I want to be able to boot it and get sideways, therefor the cage only needs to provide protection for me the driver. Even a roll bar over the front seats would do. I just want something that prevents the entire roof caving in if it decideds to roll. It doesnt need to be legally rally spec
alan1272
verde
^^ that, thats exactly what id be after!
what cage is that? is it custom?
alan1272
verde
as i said i wouldnt be driving hard enough to roll with passengers in so thats not really an issue.
billgatese30
But the diagonal bar across the back seat will make it impossible for rear passengers to sit comfortably (or even get in or out at all). They'll either have a bar about 2 inches infront of their chest, or have one to split their head in two in the event you do have an accident (even if it isn't your fault and someone hits you). Your only option if you want to retain the use of your rear seats is to bolt in/out the entire cage when you want to do a drift event. Anything else will likely cause serious/fatal injury's to you/your passengers in the case of a RTC. Same thing goes for a "show" cage which will most likely not hold up in a heavy-ish accident (read more than 30mph) and could cause worse injuries than it not being installed at all.
verde
good point, il just get a bolt in and remove it for taking the mates clubbing or what not and back in if i wanna get rowdy
billgatese30
I'd make sure anywhere on the cage near your head is well padded though. You'll certainly know about it if you hit your head on it, personally I would be wary about using a cage without using a helmet
verde
id probably take a helmet if i was gunna get super sideways and id deffo take one to the track, i fuckin hate banging my head. its the worst pain there is
aaronsmart
I've never ha a car with a roll cage and hadn't really thought about the safety side for me ad passangers. I'll have to have a good think!
ross_jsy
Cages for road cars are retarded and actually dangerous.
A cage isn't the thing that keeps you safe, it works as a system with proper bucket seats, harness' and helmet.
One without any of the others is also a danger.
For a start, when you wear harness' you have to wear them pretty dam tight so you can't move. As harness' don't stretch in an accident like normal seat belts, you need them tight so you don't get up momentum and end up snapping shoulder blades, necks etc etc. This makes it impossible to safely pull out of junctions etc . Also, a harness stops your head smashing into the huge chunks of metal that are now inches from your head. A loose harness won't do this and a 3 point safety belt certainly won't. An inch of cage padding won't do sh#t when your skull hits a steel tube at 70mph. Also you can't use the rear seats if you install harness' properly. Also, I wouldn't consider anything less than a 5 point harness so you don't end up submarining. They are quite annoying to put on and a right pain in the ass and you aren't going to want to do that for every drive to the shop.
Then you get onto seats, you need to install solid backed bucket seats to use the harness' as using harness' on a standard seat or those awful reclining buckets can break the pivot in a crash from the downward force exerted on the seat backs from the shoulder straps, potentially snapping your spine. Also buckets hold you in laterally so you can't slide off the seat into the roll over hoop in a side impact style accident. Also, rear passengers can't get in the back with fixed buckets.
Also, you ideally need to wear a helmet at all times when driving a caged car. I haven't always as it isn't practical but again, there are massive chunks of metal now in your cabin that weren't there before.
Makes for a very impractical car at the end of the day and will cost you a lot of money. Save cages for competition cars and don't drive like a cun+ on the road is my advice. Also stay away from show cages. When I was into my r5's, a forum member posted a picture of his car he rolled. Show cage had bent like butter straight down on the back of his neck pinning him against the steering wheel. Very lucky to get out of that one
Morat
What you really need is a caged, stripped, "drift spec" E30 for the weekends and your current car for the road.
Dezzy
- CR24v it's a lifestyle
What about an external cage 4x4 spec style??
Motorhole
What Ross said! If you're planning on driving hard enough on the road such that you anticipate needing a cage and helmet...glad I don't live up your way. The track is for testing your limits. And roll cage or not, you're far safer crashing your car on a track than on the road with run-off areas, deformable barriers and marshals on hand.
billgatese30
Sorry, didn't realise you were drifting on the road, thought you were doing drift days (not all have mandatory helmet rules I don't think like some RWYB days). I'd definatley stay away from a cage on the road.
verde
naa fuck that i wouldnt be drifting on the road im not that daft. somewhere quiet and shut off or a track
BATTS91
yeee ok euan i beleive that , just like i didnt have 2 non major drift incidents over the weekend
when the roads are quite assholes will shred tyres
verde
Haha I say I wont but ur probs right. What happened? Is ur car ok?
Dezzy
I couldnt agree more!!BATTS91 wrote:yeee ok euan i beleive that , just like i didnt have 2 non major drift incidents over the weekend![]()
