Post
Sun May 13, 2012 11:45 am
Quality of engine build depends entirely on the parts used and the standard of workmanship fitting them.
For instance, you could buy the best parts available, but if they're poorly assembled, it will run like a bag of nails.
There needs to be close attention given to the honing of the cylinder bores, line boring of the crank main bearings, fitting of the bearings, balancing of the rotating parts, new gaskets, careful setting up of the cam, etc, etc. Done with care and attention to detail, you can build a jewel of an engine, that is well-balanced and revs sweetly, and lasts well.
