Centre Cap modifying with lock
lukec88
hi guys i am going to be refurbishing my original sport alloys and centre caps soon and will not be the original silver. just wondering if any of you have a way of making the centre caps more secure so they dont get stolen because they are far too expensive to keep replacing and getting sprayed also..
thanks
Luke
thanks
Luke
Diamond Schwartz black 1989 325I Sport MTech 2.
polsta
im sure wed all have it if ther was a decent way
why oh why was it not done when originaly designed
lukec88
i have heard of an idea to drill through and drill and tap into the alloy and put a bolt in there that sits flush to the alloy so at least someone nicking them will need a socket set...
lukec88
or get hold of some of these bolts and do the same and get the proper key to go with it too
harry_p
It would work, but it would also look crap.
The metal cap and hidden fixing method is what sets the real deal apart from imitations.
Just a shame the country is full of thieving scum.
cheers,
harry
harry
lukec88
i know but i would rather have it looking a tiny bit worse than keep costing me to replace and respray. the wheel spokes and centre caps are going body coloured anyway so the bolts being black wouldnt stand out much tbh
lukec88
http://www.ebay.co.uk/itm/GENUINE-RENAU ... 925wt_1037
depending how long these are this could work....
sunnyr83
Nothing will work without ruining the look of the cap.
If the teefs want them, they'll get em!
They are shite, common that the key breaks when trying to remove the bolt.
Just take the caps off if you are having to leave the car for lengths of time in car parks, its the only way. Even if you try to secure them the chances are some prick will get a screwdriver behind them and cause even more damage
sunnyr83
Slow them down by pasting the cap in clear oil or something...
Unless they have the spanner tool.
Cloggy Saint
they won't work there's a wide hollow space behind the cap,lukec88 wrote:http://www.ebay.co.uk/itm/GENUINE-RENAU ... 925wt_1037
I have seen a small screw used before that goes through the nut part into the backing plate, it was discreet but noticable
Cloggy Saint
lukec88
thats why i said depending how long they are.. to see if they would clear the void before screwing in..e30topless wrote:they won't work there's a wide hollow space behind the cap,lukec88 wrote:http://www.ebay.co.uk/itm/GENUINE-RENAU ... 925wt_1037
gareth
Some of these with a stand-off underneath to allow them to be tightened down?
http://www.ebay.co.uk/itm/6-X-12-ST-STE ... _538wt_825
Not impossible to get past by any means but it'll reduce the risk
polsta
chances are- if in a car park/public parking whilst not at home where car will only be there the once for a few hours/a day, then a tool required bolt that anyone can undo with the correct tool, then that stops the opportunist who owns an e30
, but when at home/regular parked, anyone wanting them will just come back with the tool and unbolt
i'd modify the all plastic e34 ones to fit then melt some razor blades in to the nut part.
you'll get the coonts dna
+ a yard full of scrap turds
