M20 six branch manifolds - again
Brian28
Post Fri May 04, 2012 12:37 pm
I have a choice of a few different manifolds/systems at the moment for an M20. I've been looking back through old posts etc. As far a I can find, there is only one "before and after" dyno graph been done for an original BTB that showed something like 10-15 brake improvement. Also one for the Hottuning that showed a couple of brake difference. Everything else seems to be hearsay and stories from bloke down the pub, and some quick 327s had them so they must be the best. The BTB3 manifold looks significantly different to the earlier one to clear the E36 rack. Has anybody from the latest group buy actually done a before and after dyno run? It looks pretty sad, and if it didn't have a BTB badge on it and the BTB price it would very likely be slated as cheap tat.
In short - is the evidence base for the "mighty BTB" just the one dyno run from a few years ago?
Photos here
http://www.e30zone.net/modules.php?name ... c&t=219281
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri May 04, 2012 12:39 pm
Brian28
Post Fri May 04, 2012 2:49 pm
Thanks. What I'm asking really is where the "proven power gains" from the BTB3 have actually been proven, as I can't find squat?
ross_jsy
Post Fri May 04, 2012 3:02 pm
I have never driven an e30 with BTB, how ever I'm curious what you mean by they look a bit sad?
I have a zoners btb3 in my garage and I have to say, the quality is second to none
Brian28
Post Fri May 04, 2012 3:54 pm
The angle of the bends on no 2 cylinder
Post Fri May 04, 2012 8:28 pm
Brian28 wrote:In short - is the evidence base for the "mighty BTB" just the one dyno run from a few years ago?
MY dyno print out is not the only one!
For a start, mine was dyno'd on two different ones on the same day and i have print outs for both.
Also, there was a white 325i sport in Total BMW mag in 2006 with a dyno print out with the BTB2 on a standard engine giving similar results.
The BTB2 is proven!
Brian28
Post Fri May 04, 2012 9:11 pm
Not saying it was the only one, but it was the only one I could find after a while searching on here and google. Was yours the BTB1 or 2? How about the BTB3? Not trying to be argumentative, genuinely interested. It seems to be a top dollar system without a lot of dyno back up, particularly the latest one that has the odd bends to get around the E36 rack. Anybody got links to any other before/after graphs?
e301988325i
Post Fri May 04, 2012 9:56 pm
I got 10bhp from my btb3 and single 2.5" back exhaust, dynoed at the same place before and after, however with my lpg mixer inlet restriction the gains were always going to be restricted.
I said:
e30topless said:
lock the wife in there
Post Fri May 04, 2012 10:35 pm
Mine is a BTB2 and the other one in Total BMW mag i mentioned was also a BTB2.
ross_jsy
Post Sat May 05, 2012 2:49 am
I'll try and have a look at cylinder 2 tomorrow but I can't remember seeing anything sharp enough that would cause flow problems.
It does seem a very well though out system, pre bent pipes or not
Brian28
Post Sat May 05, 2012 11:05 am
Thanks e301988325i. Every car is different, but at face value and on very limited sampling it looks then like the development BTB3 makes at least five brake less than the BTB2. Still, 10 brake improvement is still an improvement :thumb:
e301988325i
Post Mon May 28, 2012 8:07 pm
Brian28 wrote:Thanks e301988325i. Every car is different, but at face value and on very limited sampling it looks then like the development BTB3 makes at least five brake less than the BTB2. Still, 10 brake improvement is still an improvement :thumb:
I haven't been on for a while, my car has a restricted inlet limiting any gains, without the restriction, HP before and after would be higher and the gains would also be higher, does that make sense? My car's struggling to get anough air in the first place, not with backpressure.
I said:
