What's worth stripping off an M20B20?
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue May 01, 2012 9:04 pm
Mine snapped its cambelt months back, and it's time to haul it out of the engine bay. But I haven't got the space to store a fat lump like that, so I want to know what's worth saving, flogging and weighing in. It'll be replaced by an M20B25, so spares will be handy
So far I've got:
SAVE:
Alternator, ICV, TPS, CPS, Blue temp sensor, dizzy and HT leads, rocker cover, sump, starter, FPR
SELL:
Injectors and rail, AFM
SCRAP:
Block, Head (since it's got bent valves), flywheel, intake manifold, throttle body
Sound about right?
johnl320
Post Tue May 01, 2012 9:09 pm
Could the flywheel and clutch be used on an m52 conversion or does it have to be the 325i one? And maybe the front pulley if its a newer engine management system. Purely to sell on.
Just thinking out loud :)
goosiegander
Zonegoose
Post Tue May 01, 2012 9:23 pm
Save the conrods for a 2.8 build :D
makman
Post Tue May 01, 2012 9:26 pm
save the flywheel clutch and starter for an m50 or 52! got my old m20b20s on mine and i larv um!
Canny Beat a chromie!'
Dezzy
CR24v it's a lifestyle
Post Tue May 01, 2012 9:30 pm
johnl320 wrote:Could the flywheel and clutch be used on an m52 conversion or does it have to be the 325i one? And maybe the front pulley if its a newer engine management system. Purely to sell on.
Flywheel and starter would be perfect for a 24v conversion. If the clutch is mint then sell it all as a set. If you have the flywheel lightened at a machine shop then it will become a very desirable set up :D
Grrrmachine
Post Tue May 01, 2012 9:31 pm
Unfortunately, I don't have the time, space or money for an M52 swap :D And these things are so cheap that I can buy more conrods in a few years time if I wanted to.
Silverfang
Post Tue May 01, 2012 11:17 pm
Save the rods as above, sell as a set for anyone wanting a 2.8 conversion
Flywheel, Clutch and starter for anyone wanting an M50/52 conversion, or want a lightend flywheel for their M20, lightened to 6kg wakes them up a lot!
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Post Wed May 02, 2012 5:34 pm
sumps worth saving also
The head will be ok i expect, how badly bent are the valves?
Grrrmachine
Post Wed May 02, 2012 5:56 pm
I haven't taken the head off yet; the belt snapped at idle, but I cranked the engine over a few times afterwards so I'm sure a few valves have taken a fair clout.
Seems like the block with crank and pistons is worth about 40-50 quid over here, so I'll pull the whole lot with gearbox, then get the gearbox off, then the flywheel and clutch, then the head off and try and sell them each individually. Whatever doesn't sell on Polish eBay gets scrapped :twisted:
The sump has been repaired in the past, so that'll be set aside as a spare.
