Hi,
I have noticed water sits in the engine bay where the battery tray is I wiped it down with a cloth it rained again and checked again to find that water is collecting their again. What could be causing this?
Also I got a bottle of water and poored it down the sunroof drains.
Water came out on the passanger side so what does this mean blocked sunroof drains/do I have a loose connection somewhere?
Water leak
lion_yo
if you remove the seal around the bulkhead you might find some krust on the lip around that area ?
+ a yard full of scrap turds
lion_yo
Removed the seal and their is no rust whatsoever.magpie wrote:if you remove the seal around the bulkhead you might find some krust on the lip around that area ?
hmm...in my knowledge if parked down hill the bonnet run offs remain clear of water,and guess what...you get puddles in the boot shuts below each corner of the rear screen .
level ground ftw
level ground ftw
Jim320i
- E30 Zone News / COTM Team
I have exactly the same fault with mine at the moment. Although I can see where mine is getting in... Where the wing lip meets the shell lip that the rubber sits in, there was a slight gap and it was dripping through there.
Also check your alignment of your bonnet as it may be sitting slightly too high so it doesnt create a tight seal once closed?
lion_yo
Have you resolved the problem?Jim320i wrote:I have exactly the same fault with mine at the moment. Although I can see where mine is getting in... Where the wing lip meets the shell lip that the rubber sits in, there was a slight gap and it was dripping through there.
Could it be that part number 9 (51 71 1 933 209)
is missing
http://bmwfans.info/parts/catalog/E30/2 ... nel_front/
Or I'm thinking the seal that goes around the bulkhead is no good?
Car is parked on a flat surface by the way.
hard to create good drainage with the aerodynamics of a concrete block.
these things need shelter .
