How do I know if I have an LSD?
BEERBOY123
It's not on the build sheet for my iS but by chance bumped into the last owner but one the other day and after much misty eyed mumblings he said it had an LSD.
I didn't like to contradict him, he may be right. Any way of telling? (Without going drifting...).
Ta
Ta
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
adit
check the tag on the rear of the diff to see if it has an S before the ratio, e.g. S 3,64
[quote="bss325i"]
rich318i
if its off the ground u can check, hold one wheel and you if you can turn the other one its not a slipper if it is a slipper they both will want to move the same
cee
Make sure it's out of gear thoughrich318i wrote:if its off the ground u can check, hold one wheel and you if you can turn the other one its not a slipper if it is a slipper they both will want to move the same
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
rich318i
would still if work in gear or notcee wrote:Make sure it's out of gear thoughrich318i wrote:if its off the ground u can check, hold one wheel and you if you can turn the other one its not a slipper if it is a slipper they both will want to move the same
cecotto479
- Caution Unreliable Seller
If its jacked up, both wheels off the ground, out of gear, handbrake off; spin one wheel by hand.
With an open diff the wheels will counter rotate and with an LSD, both wheels will turn in the same direction.
1981 E23 735i
harry_p
No it won't. If it's in gear and you hold one wheel still, trying to turn the other will also be turning the gearbox and the engine.rich318i wrote:would still if work in gear or notcee wrote:Make sure it's out of gear thoughrich318i wrote:if its off the ground u can check, hold one wheel and you if you can turn the other one its not a slipper if it is a slipper they both will want to move the same
Leaving it out of gear means you're just turning the diff and output side of the gearbox so it will turn quite easily.
cheers,
harry
harry
adit
clear, concise and accurate information ^ ^ ^ , what a refereshing changececotto479 wrote:If its jacked up, both wheels off the ground, out of gear, handbrake off; spin one wheel by hand.
i remember this discussion/argument raging not so long ago, with all sorts of theories being banded about
[quote="bss325i"]
rich318i
yeah it still bring the same out come ? lsd or notharry_p wrote:No it won't. If it's in gear and you hold one wheel still, trying to turn the other will also be turning the gearbox and the engine.rich318i wrote:would still if work in gear or notcee wrote: Make sure it's out of gear though
rich318i
best way to check 4000rpm and bang the clutch one black line or two then u will know easy
nail the turd from a standing start,
with a bit of luck you will have 2 black lines instead of a one tyre fire
sweep
It may of had a safety conversion?
redcar
Unfortunately these all apply to locked diffs as well.
Ideally, you would open the rear diff cover to check if the unit is an LSD.
cee
Causing wheelspin doesn't work. I quite often get two tyre lines even though I don't have an LSD. There are too many factors acting on it.
Easiest way is to do as above; lift and spin. Fin.
adit
is it me, or is checking the tag far too simple
[quote="bss325i"]
rich318i
drive it in the wet ffs lol soon find out if ur not used to a slipper
[quote="adit"]is it me, or is checking the tag far too simple
[/quote
Dropping the clutch at 4000rpm is more fun and easier
rich318i
Alex wrote:adit wrote:is it me, or is checking the tag far too simple[/quote
check it out
adit
rich318i wrote:Alex wrote:Dropping the clutch at 4000rpm is more fun and easieradit wrote:is it me, or is checking the tag far too simple![]()
[youtube][/youtube]
check it out
[quote="bss325i"]
BATTS91
that vid was cool lol
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
rich318i
u know that m8 but what the diff dont have a TAG?zaust wrote:Way to simple mate. To many cooks and all that lol.adit wrote:is it me, or is checking the tag far too simple
- E30 Zone Meets/Events Team
Look at all you lot, Beerboys asked another Dumb question, and sat back, while you lot argue onver the answer.
Every fooking weekend
Or what if some scammer has put an LSD tag on an open or welder?
Or what if someone has converted an open diff into an LSD?
Nankangs?cee wrote:Causing wheelspin doesn't work. I quite often get two tyre lines even though I don't have an LSD.
there's no way a baby M3 will spin up both without an LSD unless it's on slippery ground !!
rich318i
LSD is just the locking clucth m8 i thought or can u inlight?
rich318i
no open diff will spin both wheelse30topless wrote:Nankangs?cee wrote:Causing wheelspin doesn't work. I quite often get two tyre lines even though I don't have an LSD.
snakebrain
It's an iS. He'll need a LOT of luck to get any wheelspin......e30topless wrote:nail the turd from a standing start,
snakebrain
Shite - didn't see that before I posted mine.e30topless wrote:Nankangs?cee wrote:Causing wheelspin doesn't work. I quite often get two tyre lines even though I don't have an LSD.
gooner1
- Out humping Reindeer
Ask Park Lane Classics.
let me check it.
trippy diff checks are a speciality
+ a yard full of scrap turds
rix313
I'd put money on said owner being a bit of a simpleton and like most people, just says it has an LSD because thats what they 'eard down pub.
adit
Pardon?rich318i wrote:LSD is just the locking clucth m8 i thought or can u inlight?
etc.etc....
[quote="bss325i"]
zaust
- Zone day release
