drain on battery
jerrers
Wed Aug 24, 2011 9:05 pm
can anyone help - my E30 has a drain from battery when ignition switched off, which has apparently been traced to the circuit board on the instrument cluster, which i am told would be best to replace - expensive!! any thoughts please on other possible causes? am i right that components start to wear after 20 years so this sort of drain/shorting is not surprising? thanks.
Finto_316
Wed Aug 24, 2011 9:11 pm
i have the same problem buddy :x
try checking;
-does the boot light stay on when the boot is closed
-is you central locking working?
BMW e30 325i Sport-88-Diamond Shwartz
jerrers
Wed Aug 24, 2011 9:19 pm
thanks, mate, will look at these. :)
Cypriotgeeza
Wed Aug 24, 2011 9:31 pm
does your wiper motor work properly? because mine used to stutter and sometimes when id think it was off it was still trying to work but was jammed..
so all night it would be working= killed my battery a few times..only time i realised it was this was when i came out and the wipers were halfway up my screen :roll:
good luck :thumb:
Check my M30 build threads:
ucpsale
Wed Aug 24, 2011 9:46 pm
The drain can be from the si board are some of the led's iluminated / dim when ignition is off. Cheapest way to repair would be to fit new battery's to si board from maplin.
andye30m3
Wed Aug 24, 2011 11:01 pm
my m3 used to drain the battery if it was left for a couple of day, turned out to be the light in the boot.
**BANNED**
Thu Aug 25, 2011 11:49 am
jerrers wrote:can anyone help - my E30 has a drain from battery when ignition switched off, which has apparently been traced to the circuit board on the instrument cluster, which i am told would be best to replace - expensive!! any thoughts please on other possible causes? am i right that components start to wear after 20 years so this sort of drain/shorting is not surprising? thanks.
May be an idea to strip the circuit board out of the cluster and let a TV repair type guy have a look at it,or you could try a s/h cluster or board?
Youth is wasted on the young.
Lukai
Mon Aug 29, 2011 3:58 pm
I've recently noticed my glovebox light is always on, even when the ignition is switched off... that can't be right can it?
Lukai
Cypriotgeeza
Tue Aug 30, 2011 11:54 am
Lukai wrote:I've recently noticed my glovebox light is always on, even when the ignition is switched off... that can't be right can it?
I dont think it should work with the ignition off..mine doesnt.. :mad:
Tue Aug 30, 2011 1:34 pm
Change over was around mid '88, AFAIK, although of course the light should be off with the lid closed.
For the OP: Stop guessing, and get a milliamp meter connected in series with the battery earth wire, and then pull fuses to see where the excess drain is going.
Normal quiescent current is usually around 30mA on an E30, but can vary with spec.
