The Dash mpg counter doesnt work.... and the inspection light is perm on, does this mean he has the battery problem? with the early type clocks?
Also should this car have a check computer? as the previous owner said he fitted it.... But doesnt appear to be plugged into anyting.... should there be a loom there? is it possible to "make" it work or is there a lot involved?
also viscus fan coupling seams to be knackerd....wheres the best place to get one? Would you reccomend getting a secondhand one?
Many Thanks
Adam
