what can i do to fix this ?
the rear number plate lights-
got 2 new units today hella ones from euro parts
took the old out- but on one side, the tiny screw hole is missing, its nice and clean there, but looks like maybe the original screws rusted in years ago or something
so on the inside, of the left side light, i need to fix it, tried to gaffer tape a little screw thing that you use for speakers etc, to then screw a screw in to that, but tried n tried for ages and couldnt do it
any ideas ?
any ideas ?
would that work ? although maybe abit messy ?mattyb wrote:what about if you fiber glass a screw in to it let the fiber glass harden then unscrew it and use as normal
is there anything else you can like mix/squirt from a tube that sticks to metal and can be screwed in to ?
BackPeddler
Epoxy resin.
Epoxy putty.
The choose is yours....
Epoxy putty.
When a hammer is your only tool, every problem becomes a nail.
BackPeddler
The choose, don't you just love iPhone predictive text.
penton08 wrote: Or you could just fix it properly for fook sake :roll
This is good advice.
Fiber gash is never a good idea when fixing a car
You love itDezzy wrote: Fiber gash is never a good idea when fixing a car
Road HouseDezzy wrote:E30BeemerLad wrote:You love itDezzy wrote: Fiber gash is never a good idea when fixing a car
You needed it
could be right, need to order brom bmw tomorrow, cant cost much can they for 2x parts 14 and 15 to just seeRanchero wrote:Don't know if this helps but I tried taking a picture while farting about with my boot trim earlier.
I reckon it's the part at top left you need.
Jesus325iTouring
- Frog freak !
Fibre glass is the nuts if you know what type to use and how to use it DezDezzy wrote:penton08 wrote: Or you could just fix it properly for fook sake :roll
you need (14) the body nut was used on pre-face, the plastic expanding type (15) is used on facelift,
as it's a tech 1 sport it could well be rotten around the light area so fibregash may be required !
tonybtonyb
Don't mess about with it do it properly.That's why we have so many cowboys..mattyb wrote:what about if you fiber glass a screw in to it let the fiber glass harden then unscrew it and use as normal
going to order them up, theres no rot or rust there at all !!e30topless wrote:you need (14) the body nut was used on pre-face, the plastic expanding type (15) is used on facelift,
collect them fridaye30topless wrote:you need (14) the body nut was used on pre-face, the plastic expanding type (15) is used on facelift,
